Chopper Pilot wrote:Maybe I was not clear enough, I actually use my motor when the mast is up to push through waves. If you watch one of my videos, you can see me slamming the nose into the water at a different rate than I do just sailing.
Still how will a backstay help in that case, with the shock loads? The observation that the backstay does nothing still stands.
Your better option is to slow down and not slam the flat hull
Remember these boats are a hybrids they are not good sailers and they are not good stink boats either but they are both at once and generally acceptable as a compromise.
B&R rigs are support allround at 120 degrees, this is a very strong system of support the same that is used to support large transmission towers. It actually evens out the load better than 4 points at 90 degrees. Remember in engineering a triangle is stronger than a square. You have a triangle you don't need to turn it into a square
I would hate to think that you are just going to add a backstay believing that you have solved your problem and then go off powering through the chop and break your rig. We are just trying to point out that merely adding a backstay is not addressing your problem and does nothing on it's own.
