We have shore power now through extension cords and a GFI power bar that runs things like; battery charger, TV/DVD, toaster/kettle, ceramic heater, etc. Thanks to all the good friends on this site, our plan is to install higher quality power useing standard shore power connectors in the standard installation places that many others have done on the X, but my biggest unknown right now is running the wires.
Materials:
1) Breaker Panel: (Blue Sea #8143)
http://www.go2marine.com/item/114294/bl ... -8143.html
2) Through Hull Connector: (Marinco #303SSEL-B)
http://www.go2marine.com/product/70938F ... steel.html
3) Shore Power Cable: (Marinco #199119)
http://www.go2marine.com/product/247366 ... cator.html
4) Duplex Outlets: (West Marine #1591-FI)
http://www.westmarine.com/buy/marinco-- ... 70_002_508
5) Flexible Conduit:
http://superflex.com/sealproof-electric ... ubing.html
6) Inverter Option:
Source Selection Switch: (Blue Sea #303SSEL-B)
http://www.go2marine.com/product/99867F ... witch.html
* We have a 300 watt inverter I would like to install through the same system to switch the outlets between: A/C (shore power) and D/C (inverter).
Installation:
Through Hull: Aft port side of black stripe, hole going into the D/C breaker panel area.
GFI Duel Outlets: 1 @ battery charger, 1 @ port galley area, 1 @ starboard dinette area.
Breaker Panel: below factory D/C breaker panel area. (we have our stereo mounted in this area now as well)
http://www.macgregorsailors.com/modt/in ... ewimg=3664
Questions:
1) Electrical Wire:
- What kind (size) wire should I use to go from the breaker panel to the three separate outlets. (strand wire? gauge? etc.)
2) Running the wires:
- I do not want any open wires in the bilge like some installations I have seen, so I want to run the wires inside “flexible” (not solid) plastic conduit under the bilge area. Has anyone done this? I have only seen one Mac mod with PVC conduit but they used rigid grey conduit that was visible in the cabin area.
- I also want the three GFI outlets installed inside flush-mount PVC electric boxes, as well as PVC junction boxes at the points where the three wires from the breaker panel separate and go into different areas of the boat to each outlet.
Thank for any ideas and suggestions!
Darry
