Please tell me it isn't so....people really do repair scratches on their anodized aluminum?
If it were that important, then the 1976 25' Venture MacGregor I have sitting in the back yard and has logged years on salt water, should be just a Fiberglass hull! No mast, and other fittings left on her:?
Reality folks is that if you are that anal about rubbing and scratches, that's your buisness. Personally I think a few rubs gives it character....I use the damn thing!
Sheez, no bad comments if I take pictures, don't have a blue hull, and scatches all over my aluminum hardware...OK?
Having worked in Aerospace for decades, two major things to remember here. If the areas that are exposed to extreme humid conditions for a very long time, it may pose a problem. (decades) Second if the area is overlapped with disimilar metals and aluminum is the less noble metal, it may corrode galvanicaly, particularly in an oxygen deprived area, and again an electrolite solution (acidic) of some sort present. (Oh and never use aluminum wiring, even if it's free, it'l toast your boat!)
IMHO, no Aluminum surface is that vulnerable with the exception of possibly the pre-1999 rudder system on an X. And only others out there can attest to a failure because of corrosion being a factor. I again highly doubt it!
