In response to some other threads talking about the mast height: This is what happens when a lock operator says you have 38 feet of clearance under a bridge. Yes, you fit, and a windex won't go doingggg by about a foot (my estimate). Some elderly people walking by on the lock walls panicked and tried to wave me off. Perspective freaks you out a bit.
Here's a sort-of rare view of an X from 37 feet. In response to other threads talking about sailing with bimini up: yes it's possible. Mainsheet goes down between the two sections, and the backstay goes through the rear section (Cdn flag mounted on backstay), and the boom clears the front section. See photo below as well.
All I can say is WTF? That's a three-storey floating condo, not a boat. You can see my three boys probably with the same look of WTF on their faces. Well at least I can feel smug that he spent more gas money going through the lock than I did on my entire trip.
I noticed on my heavily laden and ballasted boat that the cockpit drain hole is below the waterline when people are standing in the back, and depending on wave action the self-draining cockpit reversed itself and water actually came up into the drain pit. I had a sudden fear about some sort of fitting inside the boat coming loose and the cabin filling with water. Does anyone know if this is a grounded fear? What connects the inlet and the discharge of the drain? I hope it is cast into the fiberglass...
