The compression post looks pretty good top and bottom, and there isnt any noticable give to it. I'll go bounce on it tomorrow and pay closer attention though. The deck has a nice even curve to it, doesn't look like its sagging at all anyway.topcat0399 wrote:Can't really go wrong with a $150 boat that comes with its own foredeck mounted bath tub can ya?
I have 2 things to add:
Make sure before replacing the standing rigging that that foot of the compression post and or the cabin top above the compression post have not in any way sagged. If you fit out with all new standing rigging without making sure everything is as it should be you might find yourself short. Don't ask me how I know.
Also: Your question about how the compression post attaches to the cabin roof: the way your picture shows it is typical of those earlier Macs. An angle bracket and 2 bolts. Works fine since most compression post forces are downward. On the bottom of the post its not fastened at all - its a squeeze fit.
I didn't really mean the compression post attachment since like you said it doesn't have any lateral loads. Its the mast step attachment bolts. They don't seem to thread into anything other than the deck? No nuts or anything underneath. Are the nuts embedded inside the deck?
I wanted to step the mast today and check it all out, but ran out of time after pressure washing it inside and out and adjusting valve lash on a 33ft donzi.mastreb wrote:I concur with Catigale that the standing rigging swages and eyelets look pretty good--better than my 3-year old rigging did. A little green patina on the nicopress doesn't mean anything's wrong.
I'd go ahead and rig it and see how it all looks. Examine each swage and eyelet, and if there's no broken strands or signs of serious stress, you won't need to re-do it. You can likely work the sailmaker's thimbles inside the eyelets back into place if you want to.
It isn't so much the green patina that's throwing me on the rigging as much as how much then eye is bent. Theres a couple places mid line that look like they've bent a little more than they should have as well. Stainless work hardens pretty easy, that coupled with the two that do need to be replaced, I'm leaning toward replacing them all just for the price of mind. I'm learning that doing myself should be pretty cheap and easy on a boat this size anyway. I'm new to sailing, the less worrying about unknown rigging leaves more room to lean from the countless other mistake I'm surely gonna make.
