1 local welder who can tack me on a reinforcement piece
Or
2 is there an
Please Pm me or em from board...
Pix to come
I'm no mechanical engineer, however this doesn't sound like a good idea.Catigale wrote: 1 shore up the trailer tongue with timbers and pull boat home. Not happy about this. 200 miles/4 hours. Angle iron might be better here
Seems like a reasonable solution. Probably need some new steel in there as well.2 local welding, if the metal is good enough to weld. Need help with getting a contact here.
If the rest of the trailer is in good condition, this might be a bit extreme.3 order new trailer , launch boat with shored up trailer, swap, and trailer home. Since I need a new trailer, if I can get one in reasonable time, best option here I think.
I am a mechanical engineer, and it doesn't sound like a good idea to me, either.RussMT wrote:I'm no mechanical engineer, however this doesn't sound like a good idea.Catigale wrote:1 shore up the trailer tongue with timbers and pull boat home. Not happy about this. 200 miles/4 hours. Angle iron might be better here
Easy enough to fix in the field and be safe enough for the road, then go to option 3 once safely home. Lay another 3x3x3/16 (or 3x3x1/4, if it makes you feel betterRussMT wrote:Seems like a reasonable solution. Probably need some new steel in there as well.Catigale wrote:2 local welding, if the metal is good enough to weld. Need help with getting a contact here.
