Vang me, vang me
Barnacle Jim
Vang me, vang me
Post by Barnacle Jim »
Ahoy,
Could some of the ne'er-do-wells and other respectable sailors throw a lifeline my way? I'm trying to rig the Mac 26S this summer, at least as much as I can afford.
Not sure that I am a travelin' man, but everyone seems to have a traveler. That kinda of makes me think that I may need one, and then someone comes along and says,
"A vang will do just as well, or almost as well."
Well, vang me. I don't know what to do. Yes, I've read the posts on the board here and elsewhere, but something's not connecting. I would welcome some opinions (informed and otherwise) on the use of a traveler. Several of you have one, and one sailor even built one himself. I suppose I might be able to do something like that, but maybe not. At any rate, some of you have a Harken, but what kit did you use or parts? I would be more than willing to harken to ye words.
Just sittin' around drinkin' with the rest of the guys
Six rounds bought, and I bought five
Dang me, dang me
Ought to take a rope and hang me.
-- Roger Miller
Now, I don't even drink, but the words of the silly song sure seem to fit me.
I'm always a dollar short and a day late.
Fair and sometimes unfair winds,
Barnacle Jim
81venture
Re: Vang me, vang me
Post by 81venture »
I have a spare traveler I do not plan to use
won't fit the VN23 curved stern
Whipsyjac
Location: White Rock, B.C. 96 26X Hull#486 96Merc ELPT 50HP 4 Stroke
Post by Whipsyjac »
Jim when your a few dubloons short for refitting your galleon consider a double mainsheet setup as it's half the cost ; )
Search the forum here and you'll find good advice and pictures.
Willy
Just sail your boat and have fun.
After that, you can install a vang if you want to keep,the boom from lifting up. A traveler can do that also. But most of all just have fun and don't worry about sail shape unless you plan on racing.
I would do a double mainsheet. Much less expensive, much less work, and easily modified. You simply rig a mainsheet to port and one to starboard, and then tension either or both as necessary to position the boom. Keeps the mainsheet out of the cockpit and companionway as well.
JohnWood
Post by JohnWood »
I used my mast raising pulley system as a vang. Actually, I rigged it that way thinking it was the vang and it took me a bit to figure out why it had so much extra line. I did need to install two new bales, one on the boom and one on the mast. These are the bails that I installed:
http://www.duckworksbbs.com/hardware/ri ... /index.htm
I got two "RL-334-L" and they needed a little bending on the vise to fit.
My opinion is that the function of a vang and a traveler overlap a bit, but they are not a substitute for each other. I think that a vang is a safety item, and I would not want to be without one in big wind. You don't want your boom flying up in the air without control while going downwind, a condition that can cause sudden windward roll, lack of control and unexpected, violent jibe. A traveler does not really provide this protection. A traveler is nice for racing and you want to tweak the curve of the leech. Unless I start racing, I'm not going to install a traveler. Too much hassle, and intrusion in a nice place to sit and pass through the hatch. The one downside is that you cannot raise the roof with it rigged.
JohnWood wrote:I think that a vang is a safety item, and I would not want to be without one in big wind. You don't want your boom flying up in the air without control while going downwind, a condition that can cause sudden windward roll, lack of control and unexpected, violent jibe. A traveler does not really provide this protection.
Add a preventer along with the traveler, and the boom won't go anywhere almost no matter what. With a main sail as small as these boats use, a single line with a snap hook, passed through a block snap hooked to a stantion, is all you need, terminated at the winch or back at the stern cleat for easy access if it needs to be loosened in a hurry. Those two working together gives total control of the sail and boom.
JohnWood
Post by JohnWood »
If I had a lot mor time and resources, I'd like to build something like the vang on a 49er. See it here:
http://www.mauriprosailing.com/us/categ ... -Gnav.html
Instead of pulling down from below, the boom, it pushes down from above. This would not interfere with raising the companion way hatch. It also doubles as a topping lift, so the boom wouldn't fall into to cockpit when you release the main halyard. On the 49er, the device goes inside of a sleeve in the sail. Another option would be a wishbone design, like a windsurfing boom, that goes around the sail.
