I've never tried manoeuvring with the motor locked forward (yet!) But I find that the “back and fill” technique mentioned above is much more useful in a keel boat than in our Macs. I spend as much time on my Mac as I do on a 34' Beneteau, and I switch regularly from one to the other.
While it's the only way to get a keelboat to turn on a dime, I find that the Mac will turn almost as tightly by simply using full-deflection steering (to starboard). With the DB full down it just rotates around it like a top. Much more controllable than a back and fill, particularly in wind. And way less wear and tear on the gearcase and motor.
Practise it in a narrow markered channel when no one's around like I did. I was impressed with the boat, and decided then and there that in an emergency I would never attempt a back and fill in a crowded space in the Mac, but would hard over and use throttle control instead, and just reverse if needed.
So the “back and fill” has been discarded from my mental repertoire of reaction options in an emergency situation while in the Mac. And I would want to be well-practised in open water before attempting it in a crowded marina with a keelboat though.
Prop walk is much more prominent on keelboats, but by how much depends on the prop, keel, rudder and hull shape configuration and combination. If you back out of a tight slip with the dock on the starboard side and don't allow for prop walk you'll collide with the dock every time; the stern will pull toward the dock.
In close manoeuvring you'll want to disengage and engage gear then back to neutral repeatedly to maintain just enough way to keep rudder control and use the inertia of the boat, which is something the Mac lacks, even with full ballast.
Maybe you'll luck out and get a charter with bow thrusters, or a Beneteau Sense.
You'll probably already know this stuff anyway from the course, and that's most of the battle. The academics then just need to be “fixed” in your mind by practise.
-B.
