please school me on goop!!
Wayne nicol
is see references to 4200 and 5200 all the time-
1. what is it
2.what brand name
3. where to use what- application
i look for it all the time over in the caulking dept of the hardware store- but havent found it yet
many many thanks
wayne
1. what is it
2.what brand name
many many thanks
wayne
Re: please school me on goop!!
These are sealants made by 3M that are commonly used to seal hulls and decks together as well as bolt on keels to hulls. 3M 5200is tenacious stuff and will hold for a very long time. If I remember correctly, the 4200 cures to be a bit more flexible than the 5200.Wayne nicol wrote:is see references to 4200 and 5200 all the time
Wayne nicol wrote:1. what is it
2.what brand name
Hope that helps!
- mrron_tx
Wayne: If there is a marine supply store near You , or an Academy sports store., They probably carry it/them. I ordered Mine from 3m's website. Use the 4200 if You think You might want to remove whatever piece You sealed with it....use the 5200 if You don't. West Marine also carries both. Best of luck. Ron.
Wayne nicol
thanks guys, that exactly what i needed.
so, for deck fittings do you use the butyl tape or do you use one of the above.
For deck fittings, I use butyl tape that I got from a vendor on another forum. Marvelous stuff.
- Dimitri-2000X-Tampa
I've started using 5200 for deck fittings...can't see why I want it to ever come off. And 5200 still has some degree of flexibility even if it is not as much as 4200. Also, after several years, they both age and start deteriorating and will come loose, but the 5200 will likely last a few years longer since its tougher stuff. I think I also read once that below the waterline, you only want to use 5200 and not 4200.
Wayne nicol
cool, thanks!!!!!
i also love shopping at cambodia tire
thanks fella- will get some next time i am off island!
- tlgibson97
Yep, I get 5200 at home depot. Paint dept with the glue. I haven't seen 4200 anywhere but marine stores.
