Barnacles in the bilge
- midget
- Location: 26X.. 2002. Merc. 50HP Bigfoot..Cape Coral, Fl.
Don't know why I just thought of this, but I may be glad I did! Maybe after seeing barnacles/mussels on my ballast intake/outlet. These little critters must be getting in my ballast tank (my X is in the water 24/7 behind my house) and that can't be good. Does anyone know a solution to this and a schedule for treatment? Thanks
- richandlori
waternwaves
- Chip Hindes
Do not leave those chlorine tabs in a well sealed tank for an extended period. They will outgas chlorine gas and could build pressure up to a dangerous level. BTDT with my pool filter tank. The failure was rather spectacular; fortunately I was about 100 feet away when it happened. Based on what the tank is designed to handle the pressure inside the tank to rupture it might have been 50 psi or more.
Not sure about the liquid chlorine bleach.
I'm also not sure how you want to vent the tank. Chances are the ballast tank is not gas tight, but you certainly don't want it venting into the cabin, either. Perhaps leave the transom valve cracked slightly?
zuma hans
Isn't that a bad idea?
Chlorine tabs in the ballast? How and when do you flush it out? How do you flush the ballast enough so the residual chlorine doesn't make the cabin smell whenever you vent?
And do you really want that much chlorine dumped into your immediate environment?
I would think leaving the boat on its trailer for a few days every few months would accomplish the same thing, without introducing caustic chemicals into the cabin area, much less the harbor.
- Carl Noble
- Location: Clinton Twp. MI (Former 2000 26X owner, regretting that I sold it:( Suzuki DF50
One chlorine tablet will not cause the ballast tank to give off any chlorine smell. I put one in each time I switch from unballasted to ballast. Last season when I pulled out after not changing the ballast for seven weeks the water was clear and had no smell. I think what happened to Chip was that in a pool filter there is very little water due to the filter particulates (guessing maybe two gallons? ) and if it stops running while your adding chlorine you will get a very high concentration of chorine gas building up. Glad that no one was hurt. (Other than Chip's wallet
) Lake St. Clair is zebra mussel ground zero for the States and I would never leave my ballast in without chlorine. Those little buggers attach to any thing hard including seaweed stems.
I think I'd just use 2 cups of the laundry bleach myself. As for venting the tank, guess that's just one more good reason for a passive vent hose to one of the thru-hulls.Chip Hindes wrote: ... Not sure about the liquid chlorine bleach.
I'm also not sure how you want to vent the tank. ... Perhaps leave the transom valve cracked slightly?
Bob Zoobricke
I use liquid bleach 1 cup a month, I fill the tank let it stand overnight and flush. I replaced the vent plug with a pvc valve vented through the hull. So if I keep the valve open 1/4 of the way the tank can vent from any build up of fumes. I also flush the tank with 1 gallon of bleach at the end of each season but fill the tank with clean water and not water from the Husdon River.
- Divecoz
Bleach is good as is
Bleach is good( 1 cup is enough) as is I would think . . Muratic acid. The acid is a bit more dangerous to handle though. . . I admit.
We use both products to clean and keep clean our cisterna's in Mexico as well as other 3rd world countries.
Here BTW would be my concern and that is where you dump it... Like so many other things in life . One guy doing it . . no problem. . . many . . . 100''s 1000's ???? ... Just a thought as to where to dump . Chlorine has a short life when in contact with the sun /// pools etc. I BTW use Bacacil for my pool as it's much more eco friendly .
