It still is that way but with Deep Refig. 12 volt that gets it down to -20 degrees. The Edgestar will do those temps. but not useful on our trips. Using these portable frig. one has to know when to turn on deep cycle when engine is running and turn off to 40 degrees when engine is shut off.
Appears many do not know this.
I have a Edgestar 63 portable 12Volt/ AC110 that gets down to -22 degrees. Have my boat next to house and have AC applied to my Auto 10 amp charger.
I set frig to 20 degrees before trip with all food in frig.
In morning frig. I set at 40 degrees after unplug AC. Temps are 25 degrees . I take 4 hr trip to Homestead, FL to Launch. Temps at frig. is 31 degrees. Temp. set is 40 degrees.
Took another 4 hrs to get that frig. to turn on at 40. That's 8 hrs that frig. never turned on. I turn it off at night and get 45 degrees in morning. SW Florida.
More than one way to save the juice. Run two 40 watt solar panels on bimini.
Outboard running turn that Frig. to 20 or less. Never get that far but much better than using battery power to wear down the source when you direct charge thu engine.
Getting Max outboard charging rate depends on 2/4 cycle engines but on my Merc. BF50 I get about 16 amp charge at 1400 rpms. I know all about the 27 amps the 60 2cycle does.
Point is run your frig. max. lower rating to take advantage of the running engine amp output.
Setting you refig to 20 degrees or below will not freeze food on a 6hr motor run.
Your home freezer ac will take much longer.
Three Gypsies wrote:back in the days of taking weeklong vacations on the boat .. We would deep freeze all of our meats and ice , beforehand . On departure day we load all this deep frozen stuff in a Coleman extreme cooler and cover the cooler with blankets and life jackets . We would only go in the "meat locker" once a day to get out whatever we would use that day .
We had another cooler on board for drinks , etc .
After a week in Alabama & Florida summer heat , we would come home with still partially frozen food .
Wish it was that easy living aboard !
