MacGregor 25
frscott
Sailboat: MacGregor 25
MacGregor 25
Post by frscott »
I am in the process of restoring a MacGregor 25 (1985) that I just bought. It came with the swing keel removed, any suggestions on the best way to put it back in place? Will the boat have to be hauled off the trailer? The keel is 500# (a guess) so I'm also guessing a hydraulic jack system of some type will have to be employed. I am hoping someone has done this before--so i don't have to reinvent the wheel....
Thanks
Scott
Re: MacGregor 25
Welcome!
I bet you will love that boat when finished.
Search this forum. I'm sure others have done this and you will find some information about how to do it.
81venture
Re: MacGregor 25
Post by 81venture »
1. Build this (or have a carpenter friend help)
2. Pull out the trailer
3. do keel/bottom work at leisure
4. Don't be lazy, fix up/paint trailer while boat is off
5. Replace boat on trailer
6. Beer
:D :D :D
Steve K
Sailboat: MacGregor 26D
Re: MacGregor 25
Post by Steve K »
Hi Scott,
Here are some ideas in pictures.
https://app.box.com/s/e25891a375be219e88a7
This was my Catalina 22. The cast iron keel weighed about 550#
The pics aren't exactly in order of how the job was done, so look through all 15 photos.
I think the dolly for the keel could be built using/modifying a mover's dolly ( Check Harbor Freight for one.) With the keel strapped to the dolly and rolled under the boat, you can see in one pic how it was lifted with a regular floor jack, up into place. (keel8.jpg)
There is an icon on the lower right area of each pic to click for full screen view, btw. (right next to the print icon)
Feel free to question me further :wink:
Best Breezes,
Steve K.
Steve K
Re: MacGregor 25
Post by Steve K »
All,
Thought I toss in this one other pic of my Catalina 22......... just to show off :wink:
https://app.box.com/s/fsxkwns6xkam8vnvnz8q
I figured if ancient people could move 200 ton stones, I could turn a small boat up-side-down :wink:
(kept the paint stripper out of my face :) )
Best Breezes,
SK
frscott
Re: MacGregor 25
Post by frscott »
I am planning on painting the bottom while I have it on the rack, and I must confess i will likely sneak a beer in before I finish!
The photos of the Catalina are amazing! How did you get it upside down???? Also, what did you paint the keel with? I will buy marine paint for the hull, does the same go for the keel??
Thanks for all the replies!!
Scott
Re: MacGregor 25
Or just turn the photo upside down. :D
Steve K wrote:All,
Best Breezes,
SK
Re: MacGregor 25
Post by BOAT »
If you turn the photo upside down the beer will spill out.
THE CUSCUS
Re: MacGregor 25
Post by THE CUSCUS »
Build yourself a "keel buggy" to move the beast around. to put back in, slide under the boat, attach the keel cable then use a jack to lift the front and line up the pivot bolt holes. Sometimes it helps to crank the keel winch up alittle as you jack the front up, to keep the keel level so it stays on the jack better.
The lines & arrows will help you line it up to insert the pivot bolt.
You can checkout my keel rebuild, in the mods section of this site.
http://www.macgregorsailors.com/modt/in ... ?view=1483
http://www.macgregorsailors.com/modt/in ... ?view=1484
Steve K
Re: MacGregor 25
Post by Steve K »
frscott wrote:I am planning on painting the bottom while I have it on the rack, and I must confess i will likely sneak a beer in before I finish!
Scott
Hello again Scott,
Here's some views of my gantry crane and the 22, 26X and 26D. This is what I use to manipulate the boats around. I've stripped all three and re-finished the C-22 completely.
https://app.box.com/s/1570f72f9af4c1a1fbbb
Anyway, the lifting is easy with this gantry. With the 26X and the D boat, I just lifted them off the trailers and set them on the soft ground. The flat bottom on the X boat made it necessary to rig the mast and pull it over from around the spreaders. I did this once by using the mainsheet and the vang in tandem. That was a lot of work. When I laid her over the other side, I just attached the halyard to the trailer hitch on my pickup and pulled her over with the truck.
The round bottom on the D made it easy to roll over. I just tied a rope to the stanchion on the opposite side of the boat.
Caution :!: .... I've found the round bottom boats to be a little thin along the sides so they must be supported forward and aft of the small area touching the ground when on their side. (that's why you see tire marks on the hull :wink: )
The C-22 was also easy to lift. Doing the suspended roll was a trick. I used three pullers (com-a-longs), one on each side to lift the boat (so I could lift one side very high and leave the other lower). The third one was set up with some pulleys to pull the gantry traveler across. I had a mainsheet set up to control the traveler, so the boat wouldn't just flop over when it went over center. As the boat was rolled over, the gantry crane was rolled also. (on it's four wheels) The gantry moved about ten feet from where it started. The lifting/rolling, cables were all attached to the wooden rack you see the boat sitting on. The rack was, in turn, tightly strapped to the boat (10,000# ratcheting straps)
The boat (C-22) was completely re-finished in gel coat (the same color coat material that is on a new boat). Finished the keel the same way and highly polished everything. After the bottom was re-finished and polished out. I had to be really careful, when rolling the boat back over (to avoid scratching the new finish up and because the hull was now quite slippery). To help protect the boat, I went to a carpet store and got a bunch of throw-away carpet from their bin (with their permission.... They even let me bring it back, when I was done with it.)
These boats are light for their size and are easier to move around than one might think. Having said that, I must also say that I worked for many years in warehousing and have a lot of first hand experience when it comes to moving very heavy loads and equipment in tight spaces.
Sorry this was a little long. Hope it sparked some ideas :wink:
Best Breezes,
Steve K.
Mac 26D "Three Sheets"
kdarling
Re: MacGregor 25
Post by kdarling »
Great photo's and ideas, I will be using some of these. I have to do a repair and will be needing to remove my keel. :(
