If have searched the mods and forums but cannot find any mention.
http://www.chsmith.com.au/Products/Lewm ... heels.html
They are expensive but the larger wheel would make steering feel much better.
Matt I did a mod that might work for u."Matt19020"]I have a larger wheel....If you can afford a folding one go for it...
My issue is I can not open fuel lockers fully to fill tanks...not a terrible problem but a little pain in the a$$
Not sure about easier...I never even used the stock wheel. I put this on before I put it in the water for the first timeinnervations wrote:Thanks guys for the suggestions. Mat19020 that wheel looks great. Must be easier to steer that using the stock. What diameter is it?
Thanks Skipper that is a great idea..I may look into that over the winter to see if it will clear the wheelSKIPPER2C wrote:Matt I did a mod that might work for u.
Not sure...I believe I saw something on the dismantle of the existing (stock wheel) and it stated that they (teleflex) did not recommend increasing wheel size...yukonbob wrote:How does the larger wheel do with putting extra tourque on the steering?
