One thing that many people don't think about it the transmission. Towing is very hard on an automatic, I find that renting a truck for distance is better, might as well pay 200 bucks, for unlimited miles and wear out their breaks, transmission and engine.
DEAR BOAT,
I guess I have to dig this up and re post it for you to re-read. Please take note, I said that the ENGINE is the same as an F-150 in the Flex not the Chassis, 365 HP and 350 foot pounds of Torque.
However, more IMPORTANTLY it is rated for 4500 lbs. Which makes a leagal tow vehicle with a bit of weight to spare for a
I would also like you to re-read if you may, where I stated that even though my Flex will pull, I like to rent a heavier Truck and wear it out rather than mine.
When towing, breaks and transmission are more important than engine, and above all is being safe and staying with'in your vehicles weight limits is the most important. A go-cart can pull your boat, but it is more important how you are going to control and stop it once moving.
For your information, a Peter Built Semi is a 6 cylinder
