Toyota Tundra, V8, 5.7L, tow package, 10,000 lb towing capacity!
Yipes!sirlandsalot wrote:
...it started to wobble side to side, it eventually passed the 4 runner, and flipped on it's side, pulling the 4 runner all the way onto it's roof.
In our area Home Depot delivery trucks (trucks that you can rent) have trailer hitch receivers blocked with rods welded inside them.mastreb wrote:I believe you can also tow with Home Depot delivery trucks, but I'm not positive about that.
BOAT wrote:Yeah, I know what you mean about all you F150 and Ford FLEX and RAM2500 and Tundra guys running around overloaded are talking about - a menace on the roadways.sirlandsalot wrote:It has nothing to do with your cylinders, it is what ever your GVWR is....and if you are driving around way over loaded, then you guessed right.
Only in America can they call a 1/2 ton rated vehicle a "truck". What a joke.
You see, in Germany a vehicle with less than a 3/4 ton rating is not even considered a truck, in Germany that's a car.
I use a Mercedes Sprinter van - the model 2500 - The 2500 is a 3/4 ton, and the Sprinter 3500 is a 1 ton with dual rears and a low axle. Mine is the 2500, (3/4 ton).
Unlike American and Japanese auto makers Mercedes does not even manufacture a 1/2 ton truck. Mercedes says a 1/2 ton rated anything in not a truck, that's a car.
They say if it's not 3/4 ton or more or it should not be called a truck.
My tow capacity? Don't really know - all I know is that when I came to the factory in the Sprinter to pick up 'boat' Mike Inmon said I could tow two MAC M boats at the same time. He has seen a lot of trucks tow MACs so I figure he knows what he's talking about.
(P.S. My BMW 740Li has a higher tow rating than your F150 truck)
With one exception - I believe U-Haul will rent you a truck and a trailer, such as a car carrier with the understanding you will use one to tow the other.beene wrote:Uhaul rentals will not allow you to tow anything behind their vehicles
Too much insurance risk according to the companies I have contacted
They cannot take the risk that you know what you are doing when it comes to towing something
From what I have witnessed.... it is definitely something that not all men can do
Are you serious? The F-150 is expressly designed to tow loads such as we tow with a fully loadedBOAT wrote:Yeah, I know what you mean about all you F150 and Ford FLEX and RAM2500 and Tundra guys running around overloaded are talking about - a menace on the roadways.sirlandsalot wrote:It has nothing to do with your cylinders, it is what ever your GVWR is....and if you are driving around way over loaded, then you guessed right.
Interesting! I didn't realize that the F-150 was front wheel drive, with a transverse mounted engine.BOAT wrote:... - the fact that the Flex sits on a F150 chassis sort of drives that point home...
Uhaul will let you tow our own vehicle behind a truck.RobertB wrote:With one exception - I believe U-Haul will rent you a truck and a trailer, such as a car carrier with the understanding you will use one to tow the other.beene wrote:Uhaul rentals will not allow you to tow anything behind their vehicles
That is very interesting. The European sold CR-V's are produced in GB, actually Swindon, I think. But the CR-V should pretty much be the same everywhere around the world, unlike the Accord that I know for sure will vary depending on built in Japan, USA or Europe.RussMT wrote: The American CRV has a max tow capacity of 680kg. Wouldn't do it with the US branded CRV.
