I blame it on the blue paint, myself.
mung wrote:Perhaps the Macgreggors slow reputation is based on its poor windward performance which is compensated for on other points of sail.
Regards Mung
Regards Mung
It's SO weird because I remember when Roger first came out with his boats (Venture 22 and stuff) the accommodations were horrible compared to other trailer boats. Now Rogers boat has more accommodation that ANY trailer boat!Not bad for a boat with this much accomadation and a lot of windage
This is very close to right for the conditions you describe. The Mac's easy upwind performance is about 50 degrees, as measured by my anemometer and chartplotter data.drams_1999 wrote:This means I can sail 105/2 = 52.5 degrees from directly in the eye of the wind.
They can claim the boat might point to 30 degrees but the course will not be 30 degrees to true wind. I have yet to see a GPS track showing 80 degrees of course track angle posted.Some claim the ability to get down to 30 degrees of irons using a true jib and an autohelm.
mastreb wrote:I'm going to Catalina on the 4th of October from San Diego, and will spend four days beating into the wind. I've got an anemometer, chartplotter, and will have an auto helm on by then, along with new sails and a rig retention. I'm not the world's best sailor and I don't expect much from the wind but I will be beating into it for three or four days.
My goal is to try to derive a reasonable and instrumented set of polars for the 26M with as little human factor involved as possible.
I'll post what I'm able to do.
You definitely feel like you're going faster with the wind in your face when beating, no doubt about it. That's because you've got 12 knots of wind and 6 knots of boat speed summing to the sin(60) of 18 knots.dlandersson wrote:I may be missing something. My favorite angles are 60 degrees port or starboard beating into the wind. Doesn't seem as much fun (or as fast) with the wind behind me.![]()
Actually in your description the boat is going the same speed up and down wind.mastreb wrote:But the speed is actually better.
Matt
Yep, that's correct and it's the magic of apparent wind.RobertB wrote:There is one opinion that I recently heard and I think may be true: when running with the wind, the apparent wind on your sail is the real wind minus the speed of the boat - kind of self limiting. When reaching, the faster you go, the faster the wind on the sails.
