Thinking about snagging an Endeavourcat 30 catamaran...
davesisk
Post by davesisk »
Hey guys...I am thinking about picking up an older Endeavourcat 30 that I stumbled across at a really good price. (If I did so, I'd be selling the Mac26X. Can I still occasionally visit here though? :) ) Obviously, the EC30 isn't trailerable at 30 feet long and 14.5 feet wide, so that means leaving it in a slip year-round...more expensive, but more convenient too. The EC30 still isn't quite the "floating condo" that I'm eventually after (check out the Endeavourcat 36 and 44...now THAT would do the trick!)...but it IS a huge step in the right direction. I really like the "lazy man's" sail plan on the EC30...big main and smaller self-tacking jib...very nice.
Here's a video...hit the shorter video on the right, the model I'm considering is the older one with the multiple port windows (not the newer model with the large side windows): http://www.endeavourcats.com/Hi-Rez-Gal ... videos.htm
This older model ain't the prettiest thing I've seen (it's kinda boxy), but man...there is some major room inside that cabin! I posted this because I've seen at least a couple folks who started out with a Mac26X and eventually moved to a Gemini catamaran...the Endeavour's are a second choice in that same category...a little more plush and well-equipped than a similar Gemini, but also a little slower than a Gemini (although it sure doesn't appear to be a slug in the video).
Anyway, just some musings...enjoy the link!
seahouse
Re: Thinking about snagging an Endeavourcat 30 catamaran...
Post by seahouse »
Just watched the video. Great choice Dave! The Endeavourcats have a lot going for them, and they come loaded with features as standard equipment. Plus you can keep it in the water year-round where you are? Y'er makin' me jealous (for two reasons now). :wink:
davesisk
Post by davesisk »
I'm in NC...I've got the 26X in a slip in the Wilmington area for a couple months. If I get this EC30, I'd pull the 26X out and put the EC30 in the same slip or a similar one.
Yeah, those Endeavourcats are a LOT of boat for the money...especially the one I'm considering, since it's at a great price. It needs a little minor work (like refinishing some of the teak...luckily, there's not that much wood in the boat, the sole panels and door need refinishing...the inside is primarily primarily fiberglass, as is the outside).
Seapup
Post by Seapup »
Hey dave, I have looked at a few and think I have looked at the one you are talking about if it has a teak door (most are fiberglass). Have you looked at it in person yet? If it is the one I am thinking of there were a lot of items I noticed on it, some good, some not. I think it is actually the prototype. It looked identical to the very similar intercat 28 which was the original mold. It has the same forward cat mast and fixed motor mount. The one I am thinking of has custom sugar scoops added to the rear to make up the 30' length though.
This is the one I am thinking of with the forward mast
And the standard mast location
There is also a intercat 1500 and intercat 28 available on the bay.
davesisk
Post by davesisk »
Hey Seapup...yes, I have. And the pic you posted sure looks like it. Lickety Split in VA? Yanmar diesel outboard on a fixed motor mount? (That's the worst thing I saw...I know there are jackplates to add hydraulic lift to that heavy motor, but I know they ain't cheap either). How well did you look it over? Did you do a water trial? I'm negotiating an offer with the seller, so I'll certainly take any info you might have.
Seapup
Post by Seapup »
Same boat.
The original 2 hulls ad has it listed as being special ordered before endeavourcat 30 was officially released as a model. Endeavourcat made changes to the first production model. Being a one off may make resale value of it a few years from now something to consider.
I did not take it out or hoist the sails. I like the model, but it needs more TLC than I wanted. Please don't take any negative comments about the boat personally. It would be about a grand, but I would get a good survey of it and you will know its real value and what needs fixed.
You know the good points, so here are some of what I noticed.
Everything was original, out of production, and looked like it had minimal maintenance. All electronics, wiring, fuel, water and other systems looked to need TLC. I would not even mess with the yanmar, add in price of new motor. Around the motor mount and transom there is cracking. The added scoops have cracking from bumping into things. All of the internal plywood bulkheads (bow compartments and lazerette) were soft. Under the mast step there was evidence of standing water.
If you have time to fix it up it could be a good value if you get it priced right. It would also be very easy to sink a lot of money into it. It is a lot more boat than a mac. I have many pics of it if you missed taking any you wanted.
davesisk
Post by davesisk »
Seapup wrote:Same boat.
Cool.
Seapup wrote: Please don't take any negative comments about the boat personally.
Of course not! That's why I asked. :wink: I looked it over for about 1.5 hours, so I'm sure there's plenty I missed.
Seapup wrote: You know the good points, so here are some of what I noticed....All electronics, wiring, fuel, water and other systems looked to need TLC.
Yup, they are old. They all seemed functional, but that's something I'd check. The seller claimed to have had some of the wiring replaced a couple of years ago, but I'd have to examine some of the wiring to see if that appears true.
Seapup wrote: I would not even mess with the yanmar, add in price of new motor.
I disagree for the short term, but agree in the long-term. It starts right up and runs well. Parts have to be ordered from Japan, but any Yanmar-familiar diesel mechanic should be able to work on it. The biggest drawback here IMO is the lack of a hydraulic lift. It has a spring-loaded lift mechanism...but it's still a heavy 250lb motor, and who wants to climb out of the cockpit to raise it? A hydraulic lift could prob be added for around $1K. Or replace it with a gas outboard for $5K. It also lacks a remote shutoff switch...you have to reach/climb out of the cockpit and pull a tab on the motor itself. However, I'm sure I could add a simple throttle-cable style remote shutoff myself. I also don't recall seeing a fuel-water separator, but that can be added.
Seapup wrote: Around the motor mount and transom there is cracking.
These I did NOT see. How bad were the cracks around the motor mount and transom? Surface or deeper? This would be a big concern...I'd rather the engine and mount not fall off into the drink unexpectedly!
Seapup wrote: The added scoops have cracking from bumping into things.
. Saw that...I could patch those up after I learn to stop bumping into things myself, so not too worried about those. :P
Seapup wrote: All of the internal plywood bulkheads (bow compartments and lazerette) were soft.
Ah, did not see these. How bad? I thought all of the hull was fiberglass + composite, no wood? I guess there's some glassed-over wood in those areas? You're mainly referring to the vertical wall between the bow compartments and the front interior wall, correct? I'm trying to recall where the other side of the lazarette wall would be. Repairing this would be pretty expensive...not sure I have the skills to do this well myself.
Seapup wrote: Under the mast step there was evidence of standing water.
What are your thoughts on this one?
Thanks for your time with these details!
Post by BOAT »
Looks like that cat has everything - not sure how you can go wrong with that thing.
Seapup
Post by Seapup »
Yeah, I am just not familiar with diesel and that outboard is a beast :D
Small detail, but when I looked the steering was not connecting it to the rudders. I have read a few people have used yamaha 9.9 high thrust on the boat with good success. Would be a fairly inexpensive way to repower.
I am no expert on structure.
You may be able to contact this person, he seems quite knowledgeable on the boat and started a forum for them a few years back. It seems to be down now. He had reported cracks on his transom and also replaced the mast and did work on the bulkheads if I remember right, so may have advice.
http://www.phaup.net/barefoot/photos/Sa ... andyClaws/
This is the transom around the motor mounts, did not look major.
Mast
I don't know the purpose of the bulkheads, if they are just dividers or something more. I am referencing the vertical walls of the 4 bow compartments and cockpit locker. They are plywood that was not fiberglassed. They seemed like you could push right through.
davesisk
Post by davesisk »
Seapup, thanks for those pics! I'm trying to remember (it was a week ago that I went and examined the boat initially)...was the mast pic taken by opening one of the compartments on the bow? IIRC, the mast footing doesn't sit on top the cabin...it goes to the bottom of the bridgedeck, right? A prior EC30 owner also mentioned to me that "you'll probably need to seal around the mast".
Assuming the mast footing is actually on the bridgedeck and not the cabin top, that *probably* means the bulkheads are just separaters and don't support any of the compressive downward force that the mast sees...which means that shouldn't be too hard to replace if necessary, especially since they aren't glassed. This is something I'll need to check.
Yeah, that Yanmar diesel outboard is indeed a beast. I'm not sure I'd trust a 9.9 to push something this large upwind or against currents. And yeah, that steering cable kinda surprises me (although, it's a bit like the early Gemini 3000's...there was simply a rope that connected the engine to the rudders for steering)...there's an eyelet on the loop of steel cable that hooks to the outboard to turn it, and the steel cable loop connects to the rudders on each side. There's a lot of slack in that steel cable, AND it's also another reason to have to climb out of the cockpit to raise the motor (unhook the steering first). It works, but I'm sure there's a better way that gives more precision and doesn't require you to unhook it to lift the motor.
davesisk wrote: Yeah, that Yanmar diesel outboard is indeed a beast.
This is the point that would concern me. I know nothing of Yanmar outboards. I owned an inboard and it worked great. However, it's not the actual engine that would concern me here. It's the outboard bits. Lower unit etc. Parts have got to be extremely expensive and rare. I could be wrong, but I've never seen a diesel outboard in the states.
Post by BOAT »
Hey, what could go wrong?!
Wow, looks like there might be more to deal with hear than previously suggested. How does a person know when it's the right time to walk away? (Never bought a used boat before).
davesisk
Post by davesisk »
As I understand it...the Yanmar diesel outboards were only sold in the US for a couple of years as OEM equipment primarily. The US banned them from import into the US because they pollute the water (nevermind all the inboard diesels and 2-strokes spewing unburned fuel into the water). I'm sure this had more to do with US mfg's not wanting to have to compete with diesel outboards than it did with environmental concerns. ;-)
Anyway, from everything I can gather, the few diesel outboards that did make it into the US have a really good track record. The one on this boat, although it's 22 years old, fired right up on the first spin of the starter (and it was cold beforehand...I checked). Parts have to be ordered from Japan, so I'm sure they're not cheap, but neither are gasoline outboard parts. I could prob sell this 22 year old diesel outboard off the boat for almost enough to cover a new gasoline replacement.
That said, as mentioned above, it's a boat...so something will always go wrong! ;-)
davesisk
Post by davesisk »
BOAT wrote:Hey, what could go wrong?!
LOL. Is this sarcasm, or are you being sincere?
How do you know when it's time to walk away on a used boat? That's a really good question. I guess where I draw the line is here: If it's in good enough shape that it's comfortably useable as is and doesn't need a significant percent of it's value in repairs, then it's worth considering.
You don't find that many big boats with outboard motors. I personally like outboard motors...when all else fails, they are easy to replace. I realize they have disadvantages compared to inboard or inboard/outboard power, but it sure seems the expense of maintaining those is much higher in the long run. I *wish* there was a proliferation of diesel outboards in the US...that would be ideal power for sailing craft, IMO.
You can take a boat that's in good shape but has a crappy outboard, and turn it into a great boat by merely replacing the outboard. My Mac26X for instance had an old 50hp Tohatsu carbeurated 2-stroke motor on it. It started every time and ran just fine...it was also loud, smoky, temperamental about the choke, spews pollutants into the water, not very fuel-efficient, etc...I would have probably kept it if I was only going to use it in the local lake. But since I intended to use it in the ICW and take it offshore (within sight of land of course), I replaced the old Tohatsu with a brand new fuel-injected 4-stroke Suzuki DF-50 under warranty...now I know with almost complete certainty that it'll start every time I turn the key, so it's one less thing to worry about. That new DF50 motor is quiet, powerful, and barely sips fuel...the Mac26X is like 50% new boat with it! Right now, my centerboard is lodged (probably got sand or shells in the centerboard trunk last time), so this weekend I gotta dislodge that. Even though my 26X is in good shape, it still needs work periodically. I think even a brand new boat quickly starts needing problems resolved and things maintained. True?
So...if the worst thing that I'd have to do to that EC-30 is replace a little soft wood in a non-critical storage compartment that's not too hard to get to (not something I'd want to tear into, but I could...it's probably not a "rush item" though...I'd want to replace it with composite or something that wouldn't rot again), replace the outboard at some point, run a little sealant around the mast and along the rub rail, etc., then I think I could live with that. (The teak door and the teak/holly sole panels really need to be refinished to look good...but the sole panels would be easy enough to toss in my trunk, finish them at my home, and bring 'em back next time I'm at the boat. But that's just cosmetics...it doesn't impact functionality.) The cracks in the transom might be a different story (it's hard to tell from a pic, so I'll have to look at it very closely...my 26X has some hairline cracks around the transom...but they are surface cracks in the gelcoat only...the transom itself is solid as a rock, and I'm not at all worried it'll fall off and take the new outboard for a dip...LOL). I do know that EC30 has a thick tank-uva hull with positive floatation built into it (two big pluses IMO), so some minor cracks near the transom *might* not be a big deal, especially if they are surface-only. The rigging is in good shape from what I saw...if the sails are good too and all the systems (electrical, water, head, shower, water heater, stove, frig, etc.) work, I still think it's a deal for the price. If the outboard starts and runs well, the boat sails reasonably well, and everything works well enough that it's *comfortable* to spend time on, then I can live with a few warts that eventually need attention.
The thing that makes this potentially worth it is that the EC30 is a lot of boat for the money in this particular case, and (even though it needs a little TLC), it should be reasonably easy to maintain versus other similarly sized boats. (Both the folks at Endeavour and a prior owner have told me that there are not many surprises to the maintenance...basic stuff, like seal the mast footing and rub rail every couple years, paint it every few years, bottom paint every few years, replace the steering cable every few years, etc...so I'm pretty comfortable that the maintenance would be manageable.) I wouldn't think of taking the 26X down the coast from NC to Florida and over to the Bahamas for 2 weeks. It's just not big enough and well-equipped enough to be comfortable for that big of an adventure. (I'm sure there are those who'd disagree with me, but we're all entitled to our own opinions and that's mine.) The EC30 would definitely be capable and comfortable enough for a more adventurous trip along those lines (although no time soon...I still have a lot to learn). I love being on the water...love the beach and the ocean...etc. If I could get a small beachfront condo OR a well-equipped live-aboard 40-ish foot sailing yacht for the same price, I'd definitely take the yacht instead of the condo. If I get tired of the location of the "floating condo", I can just move it. 8) (Yeah, I know...the yacht depreciates and the condo appreciates in value...but some things are just worth it.) The EC-30 hits about the 50% mark of "floating condo that still performs reasonably well" at a really good price. (If it had standing headroom throughout the whole cabin including the salon area, I would have already bought it...it's got 6'+ everywhere except the salon though...and the headroom in the queen size bunks is a little tight, and I have to duck going down the steps to either hull. Other than that, I don't have to constantly stoop...the galley, head, shower, cockpit, bimini, boom, all the areas where I actually need to stand are 6'+.) Although I definitely like a lot of things about the 26X (I wouldn't have bought it if I didn't), it hits about the 20% mark of "floating condo [camper?] that performs reasonably well". Eventually, I'd like to end up with something like the Endeavourcat 36 or 44 (or equivalent)...those definitely hit the 100% mark for "floating condo that performs well"...but that's quite a few years and dollars away. I believe this EC30 is a good step in the right direction however...as long as there's no show-stopper repairs necessary. :P
Seapup
Post by Seapup »
Sounds like the endeavourcat will work out well for you. Same line of thinking that brought me to the EC30. I really like the idea of an outboard, lots of space, and simplicity. I am just not quite ready to trade in the X yet. Maybe in a few years. Be sure to keep us updated on it and send me a PM when you are bringing it south. I am right at the mouth of the chesapeake and would love the chance to see how it feels on the water. I have sailed past Deltaville and down through Elizabeth City on the ICW a few times if you want any help moving it.
Alex
