Wayne nicol wrote:on the macs, what have you fellas found is the easiest way to change out the headsails while on the water, change from a RF set up and just use a shroud and a hank on system?
sure do like my roller furler though!!
Good question
How much money do you want to spend
Do you have your boat slipped all year or at least months at a time
Or rig each time you sail and leave on the trailer between times
Lots of factors to consider
If I had my Mac in a slip 6 months of the year, I might look into some kind of dual head sail config.
Not as complex as Highlanders, but would aim to have 2 furling sails, jib and genny
At the very least a better quality furler than the one that came with my Mac
One that I could easily swap out the sail with
Would cost a grand or more above the FF2 type for sure
So again, how much do you want to spend for the ability to be able to reef the head sail in use
For performance, you can't beat hank on, using just the forestay
But you can't reef them
Its swap it out, or put it away entirely
I have used the FF2 for 6 years
Works ok
Harder to rig with that in use
If you are a trailer sailor like I am now, your furled headsail stays horizontal for long periods
They were not intended for this
What will happen is water and mold will develop in the rolls of the sail as it is not vertical the way it was intended to be
Using that system, you can't swap out the sails easily, changing to a jib
The genny does not point well
In my area I had to roll her in 80% of the time
Again, worked ok
But not as well as the right sail for the conditions
What I use now is just the forestay with 3 hank on sails and the asym off the bow sprit
Genny, jib, storm sail, all hank on
I do not need a second hound as I no longer use the furler
Nothing gets in the way when I switch from the hank on sails to the asym
So what you choose to use is up to you, your money, your situation etc
