Quick heron H-412_D Windlass
Re: Quick heron H-412_D Windlass
Here's one more video of my project
http://s844.photobucket.com/user/TheHig ... 4.mp4.html
waternwaves
Post by waternwaves »
Still waiting to see the pics of this install John,
waternwaves wrote:Still waiting to see the pics of this install John,
Hi Darren
U'll just have to wait like everyone else !! LOL This is a big project & the weather has not been co-operating even though I am doing most of this project inside my none heated shops as I am toooo cheap to pay to heat them :) , but alot of the concept & designing & engineering of this mod is basicaly play as u go , figuring angles & cocepts that r desireable but main issue is strength combining both deck & hull into one good strong anchoring base :idea: keep watching :wink:
well slowly but surely she's coming along , here is a pic of the sticky backing tape i bought & used on the inside anchor locker brkts & on all the SS washers
http://i844.photobucket.com/albums/ab1/ ... a47c89.jpg
cut into strips two on the anchor locker walls & one each on each brkt
http://i844.photobucket.com/albums/ab1/ ... 8cf42d.jpg
http://i844.photobucket.com/albums/ab1/ ... 2215c3.jpg
Here is the center anchor locker brkt now temp installed has one more coat of paint to get
http://i844.photobucket.com/albums/ab1/ ... 3d6477.jpg
http://i844.photobucket.com/albums/ab1/ ... 1bd265.jpg
http://i844.photobucket.com/albums/ab1/ ... 22ff87.jpg
the final coat of red flrorecent paint when that dries this brkt will be mounted i picked this colour so as when the anchor locker is open theirs no mistake in knowing it !!
http://i844.photobucket.com/albums/ab1/ ... 62fda4.jpg
Here's another short vid of my swivel mounting brkt I will post another vid of it when completed without the windlass on it to let u see the mechanisim better
Well G & R showed up , G had breakfast & coffee R showed up 1/2 hr later missed breaky but had a coffee , R helped me install the last of the deck mounting brkt's the front base brkt for the hinged deck plate while the mighty G supervised ! :D :D :D :P , first install went south as the two mounting bolts were too short by 1/2" so much for G's supervisory skills :cry: so R & I had to start all over again & if u think 52 is bad wait till u try the 3M 4200 :evil: . So I took over the supervisory dept. & R & I continued on with the installation with the correct hardware , G was demoted to Goeffer & told to go get the beer's :o :P
the final deck bkt is now install & the next day I re-installed all the floatation back into the floatation chamber under the anchor locker
http://i844.photobucket.com/albums/ab1/ ... 9b0a70.jpg
so stage one is now complete & the internal & external deck base mounting brkt's have all been installed. Now to finish off stage two the hinged deck mounting plates :idea: :)
So a good time was had by all & then G tells us he is off too S/F to go sailing with Leon !! & no R & I were not invited :x
http://i844.photobucket.com/albums/ab1/ ... 3543df.jpg
Have a great time in S/F G :wink:
things are moving along slowy fit , retro fit , refit , a very slow process
Here's the finished timing plate top side
http://i844.photobucket.com/albums/ab1/ ... c22025.jpg
here is the bottom side
http://i844.photobucket.com/albums/ab1/ ... 83f921.jpg
http://i844.photobucket.com/albums/ab1/ ... 1ab0f1.jpg
middle spacer plate could not find a gasket to fit the center hole where the main wiring goes through so i used a sink drian plug & cut out the center for the wiring to go through
http://i844.photobucket.com/albums/ab1/ ... 1c8b41.jpg
http://i844.photobucket.com/albums/ab1/ ... 6f588e.jpg
http://i844.photobucket.com/albums/ab1/ ... 5c05ba.jpg
here r the mounting bolts with large fender washers insulated with rubber backing
http://i844.photobucket.com/albums/ab1/ ... 07532f.jpg
Here is the hole drilled through the deck for the battery & control wiring
http://i844.photobucket.com/albums/ab1/ ... 6bf6ba.jpg
http://i844.photobucket.com/albums/ab1/ ... f6cee5.jpg
here is the 1 1/2" conduit piping installed through the V - Berth floation chamber so from now on I can easily run elect. wiring through there, no floation was removed for this mod
http://i844.photobucket.com/albums/ab1/ ... 71f239.jpg
http://i844.photobucket.com/albums/ab1/ ... f7978b.jpg
here is the aft end of the v- berth conduit this is the elect horn wiring still to be installed
http://i844.photobucket.com/albums/ab1/ ... e8f2ca.jpg
this is where the battery cables for the windlass will be fend through to the bow
http://i844.photobucket.com/albums/ab1/ ... 88091d.jpg
All put back together nice & tidy
http://i844.photobucket.com/albums/ab1/ ... 665c24.jpg
Here's the finished stage two now it's into stage three running the 1 1/2" elect conduit for the wiring
http://s844.photobucket.com/user/TheHig ... a.mp4.html
http://s844.photobucket.com/user/TheHig ... 6.mp4.html
Well got to run another 24 ft of 1 1/2" elect. conduit through the boat then install the wiring , reverseing relay , battery ect.
had some running around to do yesterday so progress was slow the electrical cable through deck base was fitted & sealed with 5200 & left to set , then moved onto the electrical conduet I used 1 1/2" but I think 1 1/4" would have been ok this will allow me to run all my electrical cables 12v & 110v down the port side that have to be route there outlets at each end bow & stern & midships for any future wiring I may run halfway
http://i844.photobucket.com/albums/ab1/ ... 67cab0.jpg
http://i844.photobucket.com/albums/ab1/ ... 956356.jpg
http://i844.photobucket.com/albums/ab1/ ... eef483.jpg
http://i844.photobucket.com/albums/ab1/ ... ae21b2.jpg
http://s844.photobucket.com/user/TheHig ... 2.mp4.html
Hi All
Stage three is coming alone slowly installing the electrical conduet that the windlass battery cables will be route through & some other wiring that is already there will be removed & reinstalled through the conduet & reconnected , unfortuantly I had to remove my 3" return air ducting for my bilge pump so as I could get the 1 1/2" conduet installed where I wanted it , so after I finish off installing the aft section of the conduet to-day or untill I run out of material I will then reinstall the 3" air ducting, then once the run of electrcal conduet is done I'll be able to measure my elect. battery cable length & @ $5 a foot I do not want to be buying to much excess
http://i844.photobucket.com/albums/ab1/ ... 58c754.jpg
http://i844.photobucket.com/albums/ab1/ ... 07af24.jpg
http://i844.photobucket.com/albums/ab1/ ... df054c.jpg
http://i844.photobucket.com/albums/ab1/ ... 264d2c.jpg
http://i844.photobucket.com/albums/ab1/ ... 77564a.jpg
http://i844.photobucket.com/albums/ab1/ ... 92cfb3.jpg
http://i844.photobucket.com/albums/ab1/ ... b10164.jpg
http://i844.photobucket.com/albums/ab1/ ... 46b6c2.jpg
midship outlet so as I can bring wiring out there for future mods if needed
http://i844.photobucket.com/albums/ab1/ ... cd4fd4.jpg
http://i844.photobucket.com/albums/ab1/ ... c06b42.jpg
http://i844.photobucket.com/albums/ab1/ ... 315e91.jpg
http://i844.photobucket.com/albums/ab1/ ... a6093e.jpg
The elect. conduet going down the port side is zipped tied up into postion I have to make approx 5 brkts for this to make it a pernament fixed mounting this allows me to get my fixed brkt's mounting possitions but I will just leave the zip ties there anyway, that way if I have to remove the brkt's for any other future mods or alterations the conduet will still be held in its installed position :idea:
more up-dates
change this
to this much better for running the cables through
http://i844.photobucket.com/albums/ab1/ ... 919499.jpg
got all the brkt's cut & made & drilled out & installed
http://i844.photobucket.com/albums/ab1/ ... 3d55f0.jpg
http://i844.photobucket.com/albums/ab1/ ... d2ddaa.jpg
http://i844.photobucket.com/albums/ab1/ ... f37d83.jpg
http://i844.photobucket.com/albums/ab1/ ... 960b64.jpg
http://i844.photobucket.com/albums/ab1/ ... e16be9.jpg
http://i844.photobucket.com/albums/ab1/ ... 0d5321.jpg
http://i844.photobucket.com/albums/ab1/ ... 1a8cf8.jpg
next make & install battery box holding brkt's into the bottom floation tank under the V-Berth , install reversing relay, master on/off switch , 40amp circuit breaker figure out how much wiring & batter cable I need & install :D :D :D
Just ordered 30ft of tinned #6 twin sleeved dual battery cable @ 5.00$ a foot :o , should have it for fri :D
Took Sun off from working on the boat & took my youngest daughter & gran daughter to the big TO Zoo seen the Panda's , white South African Lions , Elephants , toured the whole we all had a very enjoyable day, the weather was just great to 24C nice sunny skies
She 's wired up from main independant house battery in the V-Berth work's like a charm power"s up & down or free=fall down ur choice :) , also running extra wiring for any future mods , already run wires all through the top head liner that was a major pita :evil:
have now run about 45 ft of # 6 wiring from bow bat to first house bat next to the start bat under the ladder with a kill switch just have to hook that up now but @ 90% in the shade 3 fans running it was a killer :evil: :evil:
Still have to run about 36ft of # 18 wiring from the reversing relay to the cockpit control switch in the pedestal :)
will post pic's later J 8)
Battery hold down for the V-Berth the backing plate went into the inside of the floatation chamber under the V-Berth
http://i844.photobucket.com/albums/ab1/ ... 81532d.jpg
Here's what 60ft of # 6 battery cable looks like tinned
http://i844.photobucket.com/albums/ab1/ ... 1419b7.jpg
hooking up batt cables to batt switch & kill disconnect switch
http://i844.photobucket.com/albums/ab1/ ... b57ceb.jpg
http://i844.photobucket.com/albums/ab1/ ... 3066c5.jpg
Battery & solenoid, circuit breaker installed & wired
http://i844.photobucket.com/albums/ab1/ ... 49227e.jpg
http://i844.photobucket.com/albums/ab1/ ... 48aea6.jpg
http://i844.photobucket.com/albums/ab1/ ... dd7e02.jpg
More to come vids of windlass operation , now still have to run 36ft of # 18 wiring back to the pedestal for cockpit control switch will post later
Crikey
Post by Crikey »
Becoming more impressive all the time! :)
I will give it the once over at this year's rendezvous - if there's and room left inside the boat! :D
Any hints for the next planned mod?
R.
u12fly
Post by u12fly »
Be nice to know the total weight for this installation.... windless, mount, extra battery, wire, etc. :?
