BOAT wrote:Another thing about the MAC besides heeling moment: One of the first things I figured out about the MAC was that if you have one of these it's totally useless:
If your sailing a MAC M, this thing belongs in the trash in my opinion. I have always used them on all kinds of boats but on the MAC it's nothing more than a distraction.
The problem is (I learned within two outings) is that the MAC is SO light it has way more acceleration than most boats it's size. On most boats you wait and wait and wait as wind blows harder for the boat to start to heel and move.
Not on the MAC M
My MAC and the one I tested with Mike too, both had quick acceleration in light wind - the boats QUICKLY overtake the actual wind angle with the APPARENT wind angle. It you really want to tune the MAC use APPARENT WIND not actual wind. I find that the MAC spends more time using the APPARENT wind than is does using the actual wind. If I tune to APPARENT wind, the boat holds course and speed as long as the wind does. If the wind dies, the boat gets nailed with the ACTUAL wind which is always not quite as high as the APPARENT wind and the sails become broadside to the air, and the boat naturally starts to turn away from the wind. If you tune the MAC sails to the ACTUAL wind you will always be pointing too high.
That is what I found. The results would be different if your boat is very heavy.
One of the best and most simple ways to see APPARENT wind is to use tale tells on the outer shrouds (as high as you can put them standing on your tippy toes on the deck). I ran both wind indications for several outings and it did not take me long at all to realize the old reliable Windex was just a useless distraction when trying to tune the sails on a MAC.
Watching the apparent wind will also give you clues about why the heel angle indicator is saying what it's saying and by watching the apparent wind indications (tale tells and sail yarn) you will be able to predict the heel angle before the boat even gets there and you will spend a LOT less time adjusting your mainsheet. Set it and forget it.
Waiting for my new 150% to come in from Judy B., this is the first year I'm spending much time with the 100% jib flying. This jib is original but unused. Combined with using the cabin-top tracks, I'm sailing much closer to the wind than I thought the
