You can see that it's jammed up against its ring-ding. What you might not be able to tell is that the ring-ding is rusted right there due to the water entrapment effect that causes stainless steel pitting.
You can see from the angle of the chainplate that the pin will always move to this position under pressure.
Has anyone ever seen a ringding fail? What's a simple solution here, to pin backwards (i.e., ringding up), or bend the chainplate down, to cause pressure to force the pin farther in?
This is the most important pin on the boat, so I'm a bit hesitant to make willy-nilly changes.
