Best prop for Honda BF50?
raycarlson
Re: Best prop for Honda BF50?
Post by raycarlson »
two seperate problems going on here.ventilation is easily cured by lowering your motor 1-2 positions on your transom.once you can carve tight turns with out ventilating then you move on to matching your WOT rpm to prop pitch. its very easy to get the perfect prop if you know how to go about it correctly.
Hamin' X
Post by Hamin' X »
Stanko wrote:Well my question isn't directed to achieve better performance with another prop..... I will receive Honda BF50 without prop and I have Stainless steel Solas Saturn 3-blade 10x11 wich was on Honda BF30. So, I was wondering can it fit, nothing else.
I don't think so. The BF30 has a 10 tooth spline, while the BF50 has a 13 tooth spline.
Stanko
Post by Stanko »
Thank you very much!
