What is your conclusion? Is this mod too challenging?It's also interesting that the upper and lower shroud max loading is essentially the same at 3.36F until the spreader is shortened, at which point it jumps to 4.05F for the upper and drops to 3.16F for the lower.
OK, so I find this sort of thing interesting. Not everyone does.
I wish you were around when I was doing this Mod. I know the loads and ratios changed by shortening the spreaders and I was also hoping I understood the formulas and math I used to do it. I actually shortened more than I said. However, the doing of the trick is better than knowing how to do it but letting the complexity of it stop you from proceeding.
I really like the shortened spreaders and it (mod) works well in many ways every trip out. Readers must do their own due diligence and own their own safety.
