We have only towed our
In comparison to my 1800# teardrop I certainly felt the Mac behind me.
The bumper drops about 3" when we hook up the boat.
In order to keep the trailer level I use a ball mount with a 2" drop flipped upside down to give a 1" rise.
My question is about using suspension help IE spring stiffeners air bags etc.
My biggest concern is trailer sway followed by not having the rear end drop too low.
I don't want to compromise the everyday drivability of this truck.
I checked on a Nissan Frontier Forum and came up with three options.
#1 Timbren Suspension enhancement
Features:
Hollow rubber springs sit above the axle, helping to stabilize and level the vehicle while providing a more comfortable ride by absorbing road shock and improving roll stability. Easy to install and use.
#2 Firestone Ride rite air helper springs
Features:
For safety and stability, air springs are the perfect partner for your rear suspension when you are hauling heavy loads. Springs reduce strain on your rear axle, keep your vehicle level, and adjust to load sizes for a consistently smooth ride.
#3 Supersprings
Features:
Install these beefy helper leaf springs above your vehicle's rear factory leaf springs. SuperSprings reduce sway and prevent sagging - great for towing or hauling heavy loads. Additional mount kit included for OEM springs that set above the axle.
http://www.etrailer.com/susp-2009_Nissan_Frontier.htm
Any thoughts or experiences with these product? or other suggestions.....
Hugh
