I don't use a mast raiseing Gin pole, tho I have a M gin pole.
Johnson quick release lever on backstay or headstay is all thats required for tension to pin the headstay.
Takes my Girlfriend and I to set up boat and launch in 15 min. and don't want any equipment added to take longer.
We been doing this for 4 years on my MacX and tho tuning the rig isn't perfect it is good enough to take a knock down without damage to rigging.
Adding a wood dowel 10 inches inside spreaders will save them from bending out of shape.
Having the Main up Hauled in tight while motor sailing is a great way to prevent roll movement when large powerboats pass leaving 4 ft. wake.
One needs to take these waves about 3 points off the bow (30-40 degrees) so you don't wip lash the main causeing tremendus strain on the standing riiging.
Just like you don't jibb the main in heavy winds.
Spare rigging is best done with Sta-lock or Norseman fittings as these don't require Tools to Swag.
If one ever has a standing wire failure, most likely the mast will fold in half, therefore spare wires won't help.
Haveing a 5/32 headstay 1x19 wire will make a diffrence in your safety.
delevi wrote:I switched to 5/32 on the forestay. Consequently, it sagged more than the 1/8. I compensated for this since I had a backstay rigged. Otherwise the 5/32 would require more shroud tension if you want the boat to point reasonably well.
Toggles: Absolutely. Mine didn't come rigged with a top toggle. Noticed damage to the forestay at the very top and had to replace. Not sure if it was from lack of a toggle or a kink caused from transport with the furler pulling on the cable. It looked like the top of the furler was cutting through the cable. Glad I caught it when I did. I found it sadly amusing that the CDI manual makes a big deal about how imperative it is to have toggles, yet the boat was rigged without it.
