I want to install a Blue Seas 8 position 8676 DC Breaker Panel because it will fit the existing spot without any serious modifications. Next to that I could fit an ammeter (Blue Seas 8254 Click here) and a voltmeter or a digital multimeter (Blue Seas 8248 Click here).
Heres the Blue Seas web site: Click here. The engine is a Suzuki DF70. Not sure what the charging amps are on the alternator - the manual says 51.5 kW as maximum output??
Now for the questions:
Why is the mast light on a separate circuit from the running lights? Wouldnt you always run them at the same time? Would it be too many amps for the circuit? Id like to combine them to free up a circuit for something else.
How does the voltmeter tell me the status of the battery? For example if I use the house battery will it show 6 volts rather than 12?
Does the amp meter show the real-time usage, i.e. the charge going into the battery from the alternator or the charge coming out of the battery from usage?
Is there a better way to monitor the status of the batteries?
Do the analog amp/voltmeters use any energy themselves? I was thinking of using a 3-position switch to toggle between battery 1, 2 and nothing (to prevent battery drain).
Here are the circuits I currently have planned:
* Cabin lights
* Running lights + Masthead light + Compass
* Auxiliary (12v power plugs)
* Outside & Inside LED lights (both with switches)
* Stereo
* VHF radio
* Water system
* What am I missing?
Thanks in advance!
