We draged until the Fortress F11 set but stearn was only in 2 ft. of water from beach and beach had Astralian Tree stumps in 1 ft. of water and we had to fend off the boat that seamed hours (30 min. acturally) from putting hole in boat.
We came out fine with a light scratch on port side when we bumped rails on another boat we were suppose to raft up.
All boats anchored ended on the beach and all but one needed Sea Tow to pull them off.
Leason learned: Anchor in open area on a windward Island on the Lee side and have outboard going.Also use the Knowledge you have learned and stick by it.( by this I mean I had a option to go to Popcorn Bay thats very well protected and closer but chose to beat the storm, I lost)
PS: getting hit with rain at 70 mph is almost like bb gun pellits hitting you
Catigale wrote:A furled stock genoa in high winds will be blown out quickly, after which the clew will likely fail....life would then get interesting as the sail unfurls in high wind...I'm guessing above 40 kts sustained things will go to hull in hand basket pdq.
