I just set the sails, we were on a port tack sailing between a close reach and a beam reach with about 12 kts of wind and a gust between 15 and 20 kts hit and the mast just snapped in half. It was surreal, I could not believe that it just happened to me.
Fortunately nobody was hurt. The outboard was off at the time so nothing wrapped around the prop. I was also happy that both my main sail, roller furler and genoa all survived the incident unscathed. I had a small chunk of gelcoat knocked out of the sliding top hatch and the mast base bracket got tweaked a bit.
The crack originated in the hole for the lower side stay mounting bolt. There is a little corrosion (possibly galvanic) right around the hole.
Here is the kicker, I think my rigging adjustment was just too loose. To help making rigger easier, I attached a turnbuckle to the back stay. When raising the mast, the back stay was slacked which made it fairly easy to attach the pin on the base of the furler. Afterwords I would tighten the back stay. However, I never really set the side stays so they would be very tight. As I was rigging today, I was commenting how much easier it was to raise the mast than on my previous boat.
I think with a little slack on the side stays and a strong gust of wind the mast bowed and then broke as it flexed. Had my side stays been tighter, they would have prevented the mast from bending as much and the leeward side of the mast would not have been placed in as much tension and I would not be sitting here telling this fine community about my lousy day
Time to order a new mast from Bluewater Yachts.
