replacement tracks for companionway
jion
Sailboat: MacGregor 25
Post by jion »
I need to replace the wooden companionway/hatch slider tracks on my Mac25. I'm not a do it yourself kind of guy. Does anybody sell these replacement parts? I checked MacGregorowners.com, but no luck. Is this part called a "slider track" or is there some other name that I should look for?
Thanks for your help,
Mark
Freedom77
Re: replacement tracks for companionway
Post by Freedom77 »
What part of the world are you in? Contact H&L Marine woodworking in Los Angeles, @ 310-638-8746. They will produce teak hatchglides and companion way glides to your specs. When you speak to them request a catalog. I have purchased many items from them over the past 40+ years and have been satisfied. I have also brought raw stock and fabricated some things myself. They may even have the specs for your boat on file. Also try Bluewater Yachts in Seattle @ 800-688-8626. Good Luck. Fair Winds and Full Sails....Old Salt
frede
Location: Washington Sailing Marina, Alexandria VA - 2005 26M 50hp Honda - Kool Breeze
Post by frede »
IdaSailor has 'em :wink:
This is a complete white hdpe replacement set for the hatch tracks on all Macgregor/Venture 21, 22, 23, 24 and 25' sailboats. These tracks are milled from solid UV formula hdpe and are white in color to match your deck. They require no varnish or other maintenance and have a smooth finish. The set includes two drop hatch board tracks, 22" long and two sliding hatch tracks, 48" long. The profile is an exact replacement for your old, gray, cracked, teak originals. Install takes around 45 minutes and the new tracks immediately lend a fresh, updated look to the deck and cockpit. Lifetime warranty against failure.
http://www.idasailor.com/catalog/produc ... cts_id=413
