The Bucket - good!
The Anchor sail - good!
Rear Anchors - not good in windage
Double front Anchors - small insurance
Rudders down and pidgeon toed by disconnecting linkage - probably good with one of the above
I've just finished a linkage mod that will allow me to do this (try). We've a week coming up moored in an unknow bottom bay off Massauga Provincial park, up near the North Channel, Huron, Ontario. I will try all three (first two) eventually because reducing and not eliminating the weathervaning is the object. I've tried lashing the rudder in a past boat that like to moor sail (Sandpiper) and found no difference with centre or biased positioning of the helm, other that to push the swing more to one side, depending on the prevailing wind. It occurred to me that fixing both blades in a 'toed' orientation might add some stronger sternward drag without the handedness. I suppose if the power reserves were sufficient, running an autopilot could cancel out some phases. Though you'd need an - Anchoring - macro.
Ross
