How to determine your tongue wieght. After I learned how, I was embaressed on how easy it was. I visited a website that offered a $400 device to calculate it. Armed with that information I visited the local wieght station and determined my tongue wieght.
My local truck stop has a wieght station. $10 for intial weight and $1 for re-wieghts. I guess the guys weight the truck and then go have it loaded and return for a re-weight.
Here is the process (it will be obvious once you do it once but you won't have to do it again)
1- Load up your boat with all the usual stuff - outboard motor, full tanks of gas, mojito premix etc
2 - With the trailor and jack stand on the scale, get a weight. (Make sure your tow vehicle is off the scale)
3- Now raise the trailor off the hitch ball and re-weigh. (jackstand must be on the scale)
4- The difference will be the tonque wieght.
The factory supplied trailor has the winch welded to the trailor frame so you can't simply move the nose of the boat forward or back. Jack up your trailor and move the axle as required to get the tongue weight correct, 10% of total. An inch or two changes a lot.
That said I would guess the factory delivered tongue wieght
is about 200lbs since it floats up if unhitched with my 200lbs and 50lb kicker on the back.
Next week, I'm taking my 26m in and having a ETEC 90 hp installed. I'm sure I'll be playing with the placement of the axle to achieve 10% wieght on the tongue.
FYI when I bought my Catalina its tongue wieght was only 5% and I had several near death experiences with trailor sway on my first trip.
