I have some damage to the stern of my
https://picasaweb.google.com/lh/photo/c ... directlink
Randy
Thanks for the advice.tomchitecture wrote:It definitely looks like something you can do yourself. I cant tell if you are missing and strand or roving material or just gelcoat and resin. Bondo makes a product that has glass fibers in it called bondoglass. I would sand off an area of paint about 3" around all sides of repair then fill with bondoglass. If you want to be extra sure, I would add a sheet of 2-3oz fiberglass matt while the bondoglass is still curing over the entire sanded area, wet with west system resin and let cure 48 hours. Then I would sand the whole area, feathering out the edges and re-apply bottom paint. Don't use automotive grade matt and resin.
If you don't think you need the matt on top, I have had great results sanding and painting the bondoglass. Looks great and you never knew there was a repair there.
Thanks everyone for the great advice! So does it look like just a gel coat repair (click on pic for close up)? In other words, I don't need to use any fibeglass cloth? Is there a difference in strength between repairing with gel coat vs marine tex?kmclemore wrote:I second that - under NO circumstances should you use Bondo, since Bondo is not watertight and will eventually absorb water and begin get soft to flake away from the substrate.
Use what the factory used - gel coat. Best way it to make a plasticine mold from the nearby or other side's lip, coat it with mold release fluid, and use that to exactly match the existing area. Fill the area, apply the mold and keep in place until completely hard (about 6 hours). If you don't want to go to the trouble of making a mold you could also use Saran wrap. The important part is to not let oxygen get to the surface of the gel while it is hardening, and to maintain the shape you want.
trdprotruck wrote:Thanks everyone! You guys really make this website awesome. I was a little hesitant at first, but now I think I am just going to clean up / bevel the damaged area and then fill it with Marine-Tex.
Thanks again,
Randy
trdprotruck wrote:Thanks for the advice.tomchitecture wrote:It definitely looks like something you can do yourself. I cant tell if you are missing and strand or roving material or just gelcoat and resin. Bondo makes a product that has glass fibers in it called bondoglass. I would sand off an area of paint about 3" around all sides of repair then fill with bondoglass. If you want to be extra sure, I would add a sheet of 2-3oz fiberglass matt while the bondoglass is still curing over the entire sanded area, wet with west system resin and let cure 48 hours. Then I would sand the whole area, feathering out the edges and re-apply bottom paint. Don't use automotive grade matt and resin.
Here's a better closeup. I think it's getting into the mat.
-Randy
Pssst, Bondo is a trade name, not a product. There is Marine bondo of course. This filler looks promising.since Bondo is not watertight and will eventually absorb water
Scott wrote:Pssst, Bondo is a trade name, not a product. There is Marine bondo of course. This filler looks promising.since Bondo is not watertight and will eventually absorb water
http://www.jamestowndistributors.com/us ... o?pid=6146
