mast angle more than 94 deg
eddy
Post by eddy »
Yesterday i discovered that the angle of my mast was much more than the 94deg mentioned in the :macx: manual. :|
How much affects this the sailing performance?
bscott
Re: mast angle more than 94 deg
Post by bscott »
Anything beyond 3 degs aft will cause too much weather helm.
Bob
Eddy - its more than likely that your whole rigging is not setup correctly if this is the case.
eddy
Post by eddy »
I bought the boat with this setup and sailed it for more than a year.
But wondered last year why my mast angle was far more aft then the other sailboats. Think i gonna try to reduce the angle to the 94 deg this weekend, don't know how but will try :?
I'm curious how the new mast angle works out.
wcole
Post by wcole »
During the first year I had my X I progressively shortened the forestay adjustment and lengthened the shrouds to set the mast more vertical. Eventually I got a new shorter forestay and now have the mast very near vertical. The main benefit is a balanced helm and minimum weather helm. In most winds, I can trim the rig to be neutral and maintain a steady course with little or no steering input. Frequently long enough for a quick trip below. Be careful doing this, however. Many would consider it unsafe because if I were to falll overboard, the boat would continue to sail on. With weather helm, it will turn up into the wind and stop making is possible (hopefully) to swim to the boat and board.
Bill
eddy
Post by eddy »
Don't know if i'm able to get the mast to 90deg because of the shroud en forestay length.
But i'll have a try this weekend.
Judy B
Location: San Francisco Bay area and any where my hybrid SUV can tow my boat
Post by Judy B »
eddy wrote:Don't know if i'm able to get the mast to 90deg because of the shroud en forestay length.
If the shrouds are too short, you can add a toggle at the top or bottom. They come in various lengths.
Fair winds,
Judy
Reason: Edited IMG
wcole
Post by wcole »
My mast is very close to 90 degrees. The shrouds are near their maximum extension. I have replaced the forestay with one that is shorter (I've forgotten by how much, maybe 6").
Again, be very careful because this can eliminate weather helm which is probably why the factory has the rearward cant of the mast.
Bill
mika
Post by mika »
What's the best way to determine the exact degree angle of one's mast?
mika wrote:What's the best way to determine the exact degree angle of one's mast?
An iPhone App called "Theodolite". You line up the vertical line with the mast, and it tells you the exact angle.
Matt
eddy
Post by eddy »
Hmmm, think i'm going to set the mast at 94deg as mentioned in the manual for the :macx:
I have a cut piece of cardboard with an angle of 94 deg so i can check this.
raycarlson
Post by raycarlson »
94 degrees to what ???? boat on or off trailer or floating in water???? my M floats nose down when viewing water line stripe so thats not accurate. 94 degrees + or - 4 is prettty hard to keep in tolerance with out some expensive jigging of boat
eddy
Post by eddy »
Don't know about the :macm: but in the :macx: manual on page 12 it should be 94deg from the flat spot under the mast.
wcole
Post by wcole »
I followed the directions in my memory of the 26X manual. I extend the main halyard to the deck and put a weight on it and take up the slack when there is no wind. I then measure the distance between the halyard end and the mast base. 0" is 90 degrees. The manual states what distance they recommend (this may be the 94 deg). I believe mine is about 1".
Bill
DaveB
Post by DaveB »
Mac.X should have a 1.5-2 degree aft rake with a slight bend aft at top of Mast.
This is for well trimed Balanced Headsail and Main.
Adjust Headsail or Main for a balance helm beating to Windward.
Always have a little weather helm.
Sheet angle of the Headstay should be about 60-65 percent up the Stay for correct angle, so adjust your pully along track to get correct angle.
This will keep your headsail in proper aligment when sailing and furling the sail.
This is close as I can get to beating to windward and do as much as 40- 42 degrees in 10 knots (heel 15 degrees) of wind beating to windward and do 4-4.5 knots in a 1-2 ft. wave with full Sail and a 105 jib.
I have done closer to 38 degrees in 12-15 knots of wind and doing 6 knots at times in 3-4 ft. seas (heel 15-20 degrees) but thats Gulf waters.
Gusts are always higher in heel and speed but I won't include that.
wcole wrote:I followed the directions in my memory of the 26X manual. I extend the main halyard to the deck and put a weight on it and take up the slack when there is no wind. I then measure the distance between the halyard end and the mast base. 0" is 90 degrees. The manual states what distance they recommend (this may be the 94 deg). I believe mine is about 1".
Bill
