And the answer is....about 3 pounds (1.4 kg).Ixneigh wrote:I have no idea what a hen weight is.
Why do some say the M sails better than the X?
- frede
- Location: Washington Sailing Marina, Alexandria VA - 2005 26M 50hp Honda - Kool Breeze
Re: Why do some say the M sails better than the X?
- bscott
3' taller mast with larger main; rotating mast (when it rotates as advertised); blue hull provided it is waxed and shiney.
You can make an
Both boats will sail with their DB/CB up in thin water. a CB will swing off the bottom, a DB can run aground.
"continued"
Bob
- David Mellon
Another difference is the cockpit, larger on the X, more comfortable. The cabin in the M feels more roomy to me. I've never used the head in an X but it seems to have more "head room" then my M.
bobmonroe
- Location: winter-Vero Beach, FL. Summer- Saluda. NC '99 26X, 50 Etec, Chevvy Tahoe
There are skipper's that will beat you in their "M".
The same skipper can sail your "X" and beat his "M".
The only way to learn how to sail to the best of your
boat's ability, is to race in a club.
Otherwise, your a cruiser, which is no bad life either.
Doesn't matter.......both are slow ...so what.....its the total concept that's a winner....trailerable,huge inside,water ballast etc etc....may not be perfect but a good compromise
