| ! | kmclemore: |
| Revised title for clarity and easier searching in future |
Removing a Motor - How to?
I have a 2001 honda bf 50 on my 26x. need to know what is involved in removing it from boat. It needs some tlc from a pro. so taking it to marine mechanic.
- vkmaynard
Re: Removing a Motor - How to?
Drain the oil and gas, remove the steering connection, control and electrical cables and use an engine hoist to lift it off the boat. Support the engine on it's side (not the cover) it you can't tie is in in place setting on the mounting bracket. We used a low small utility trailer to haul the motors.
Victor
Victor
- pokerrick1
- Sailboat: Venture 23
1) loosen the engine thingys that hold the engine on the transom
2) Loosen or disconnect all other connections
3) Turn the boat upsidedown
Rick
Rick
- mallardjusted
- Location: Puget Sound, 2001 Sold Oct2021 "Aqua Dawg", 70hp Yam
Just curious ......... can't you take the motor and boat as is to the mechanic, or are they that limited for space? Do you have other mechanics in the area that could work on it? I just can't imagine taking my outboard off to have it worked on!
- c130king
Same here. I took my entire boat to the shop...was the only sailboat there amongst all the ski boats, fishing boats, pontoon boats, and cruising stink potters.mallardjusted wrote:Just curious ......... can't you take the motor and boat as is to the mechanic, or are they that limited for space? Do you have other mechanics in the area that could work on it? I just can't imagine taking my outboard off to have it worked on!
But then again I am not very mechanically inclined.
Good luck.
- Crikey
Remember to plug the engine bolt holes if you take it off and go sailing!
