leak when it rains
tom clayton
leak when it rains
Post by tom clayton »
I keep getting water in the cabin when it rains it has a dodger on it with the hatch closed and locked up. it trickles down the starbard side and onto the bed anyone else have this issue? Tom. :macm:
Octaman
Re: leak when it rains
Post by Octaman »
You may want to check the cleat for the keel on the coachroof.
Octaman 8)
madguy
Post by madguy »
tom clayton wrote:I keep getting water in the cabin when it rains it has a dodger on it with the hatch closed and locked up. it trickles down the starbard side and onto the bed anyone else have this issue? Tom. :macm:
Ohhh the joy of Macin, nearly as good as campin..
madguy :evil:
jschrade
Post by jschrade »
Is it running down the carpet on the wall or dripping out the hole in the center of the bed, under the pedestal? Mine has leaked where the pedestal cables come through. It looks like it was related to water getting into the fitting used to run the GPS cable into the pedestal. I also wonder how "sealed" the base of the pedestal is.
Jim :macm:
bwygirl
Post by bwygirl »
Hi Tom, give me a call and I can talk to you about this. Happy to help you track down the source. Cheryl
Dennis
Post by Dennis »
Tom: My :macm: occsionally leaks in the vicinity of the starboard side traveler fastener. It appears to come in at the traveler bolt cover. Dennis
tom clayton
thanks guys, it is running down the wall has made a nice little stain so its pretty easy to see the track but im not sure where it starts at thought it might be the hatch cover now im not so sure. Cheryl i will give you a call about it probably on monday i work all weekend thanks Tom.
Doug W
Post by Doug W »
At one point last summer, I had woke up to water inside the ceiling near the head door. I popped off the interior access caps to the port forward jib track, had my son squirt the boat with a hose and found one of the bolts loose holding the track on.
Doug :macm: Galactica
http://starsloop.blogspot.com
bartmac
Post by bartmac »
Not just Macs but all boats....where are the most holes... hull or deck....Our Mac26X leaked but all sweet water coming in as rain through EVERY hole ever drilled for a miriad of deck fittings....it took a lot of work to seal them all.Actually I haven't finished the steering binnacle.Leaks also start in one place and then exhibit themselves elsewhere.
Every boat we've owned has leaked....its a real pain in the @#$%
esc
Post by esc »
My '96 :macx: has a leak that collects water in the light fixture over the table, then spills down onto the table and collects under the Plexiglas, soaking any map you might want to put down there. I've been meaning to try and track it down, but have not had time yet.
When I trailer in the rain, water comes in all around the companionway hatch.
SeaGriff
Post by SeaGriff »
esc my 97X leaked in the same place into the light over the table.
I took the bolt holding the keel lift block off resiliconed it and
that fixed the leak. Havn't had any other leaks.
Dido
Post by Dido »
Whereever there is a white access cap in to roof there is the chance of a leak, on our 99X we had a leak above the Fore side of the table, we took all the caps of and then one of use used a hose on the outside, after a little while water was visible on the inside below the keel pully fixing, the nut sheard when I tried to tighten it, I replace the nut and bolt with a new stainless steel one and the leak stopped. I have another very occasional leak from one of the companion track bolts but it only appears in extreme rain, I get more drips from condensation after a night aboard so I'm not in a rush to fix that leak quite yet.
Si
esc
Post by esc »
SeaGriff wrote:esc my 97X leaked in the same place into the light over the table.
Thanks, I'll check that one first.
bwygirl
Post by bwygirl »
Hi Tom, Remember we are closed Sunday and Monday. Give me a call Tuesday or later. Thanks Cheryl
deadbat
Post by deadbat »
I am a new owner of a 99 Mac X and I have been getting a rain water leak on the fiberglas panel, just forward of the transom. The leak seems to be comming from a spot through the fiberglas layers on both sides of the aft collection/drainage bowl. The leak spot is black and runs down the backside of the panel, collects in the channel formed into the bottom of the panel and drips into the aft berth. I have a pic that I would email anyone willing to take a look.
Any suggestions?
Thanks.
