I didn't know that the release pressure was adjustable. That makes a big difference.Sumner wrote:Just so you know you can adjust the release tension needed with the cleat. Good luck with the bungee and don't forget you don't want the rudder coming up while underway at all as it will stress the rudder and bracket more and more the further it is up.esc wrote:.....I would like to look at the relative tension needed to lift the rudder against the bungee vs free it with the self releasing cleat and what damage could be done by the innitial impact.........
Sum
As for the rudders coming up, I did experience that the first time I took it out and my "crew" didn't know to tie the rudder in the down position. It felt like something was jamming the steering. Luckily it didn't take much investigating to find out what was wrong.
I'm starting to think that a releasing cleat would be a good idea for the center board as well.
