Google Maps
- Fred Rio
Google Maps
Hello,
I found a neat way to share GPS tracks using Google maps. I take the track off of my GPS and save it as a kml and then upload it to a custom map in Google maps. If your GPS software won't save kml use http://www.gpsvisualizer.com
http://maps.google.com/maps/ms?ie=UTF8& ... 1&t=h&z=11
Fred
Fred
Re: Google Maps
If you have an Android phone, download EarthNC from the android market. A phenomenal GPS / charting solution. There's a free and a $10 version. You can even save charts to your memory card so you can use them without a cell signal, just with your GPS.
- Phil M
Re: Google Maps
What is a kml?Fred Rio wrote:Hello,
Fred
Phil M
- kmclemore
Re: Google Maps
KML is the file format that the program Google Maps uses to import/save geographic data.
- pokerrick1
- Sailboat: Venture 23
- r.fairman
Re: Google Maps
If you have bsb charts you can convert the .kap file to overlay Google Earth satellite images so you can see depth data and navigation marks. The chart overlay is transparent so you can still see the satellite image. Any NOAA raster chart can be converted in this way In the reverse direction you can convert a GE satellite image to a kap file to display in SeaClear OpenCPN Polarview etc.
- Phil M
Re: Google Maps
r.fairman wrote:If you have bsb charts you can convert the .kap file to overlay Google Earth satellite images so you can see depth data and navigation marks. The chart overlay is transparent so you can still see the satellite image. Any NOAA raster chart can be converted in this way In the reverse direction you can convert a GE satellite image to a kap file to display in SeaClear OpenCPN Polarview etc.
Hmmm. I think we should stick to English on this board.
Phil M
- Rick Westlake
Re: Google Maps
No, Know It All would be KIL. KML is "Keyhole Markup Language." You find it being used in ArcGIS as well.pokerrick1 wrote:Know-it-all
- kmclemore
Re: Google Maps
That's 'Kevin's Moustache is Luxurious', Steph.Catigale wrote:It actually stands for Kevins moustache is Long if check Wikipedia...
