I would say this is probably my experience in themagnetic wrote: ...At sea, in 15 knots TRUE and heeled at around 20 degrees I can typically maintain around 4 knots SOG at 45 degrees to the APPARENT wind, although VMG towards a windward mark is far less due to leeway and the the fact that the apparent wind moves forwards quite significantly, such that I am probably closer to 60 degrees off the TRUE wind. Hope this helps.
And I don't race...just push myself to get as much performance as I can for the given situations.
In the winds as described by Hector I would have had my Genny rolled in half-way or maybe more and my one and only reef set...and then probably would have given up shortly after that and called it a day.
Don't like to work too hard when I single-hand.
Sailing on König
