capncarp wrote:Gypsy,
Your trying to split hairs with symatics and you are incorrect. I am sitting here reading the" U.S.C.G. Navigation Rules". This is the official, legal printing of Colregs. First if you friend knows every faction of the regs, then he should have explained all of it. Not just what you wanted to hear. You are correct in what Rule 30 (anchored vessels) International and inland say. However, now you need to define "all around" light. Rule 21 states , para (e) "All-around light" means a light showing an unbroken light over an arc of the horizon of 360 degrees. "UNBROKEN". Your arc as you want is broken by height. It doesn't matter that the beam goes 360 degrees. It has to be unbroken. Everyone should have a copy of the colregs on board.
capncarp,
U.S.C.G. licensed Capt.
Rule 30 : Anchored Vessels and vessels aground
(a) A vessel shall exhibit where it can best be seen :
(i) in the fore part , an all around white light or one ball ;
(ii) at or near the stern and at a lower level than the light prescribed in sub-paragraph (i) an
all-round white light.
(b) A vessel less than 50 metres in length may exhibit an all around white light where it can be best instead of the lights prescribed in paragraph (a) of this Rule.
I copied the above , straight out of the rule book , my friend gave me , which is 'Nautical Emergencies ' and contains the COLREGS
The interpretation is my own.
You might be right that it means two all around white lights , but I took it to mean two lights
making up 360 degrees , since it would be nearly impossible to have two lights on a sailboat shinning 360 degrees each . One would have to be on top the mast , but the stern light would be partially blocked by rigging and the mast .
By what you are saying the only legal anchor light is a 360 degree white light on top of the mast .
The only legal way to use two lights would be to have two mast , the aft mast shorter than the fore mast and a white light on top of both .
I started this thread because I am in the process of completely rewiring my boat and wanted to know what others have done , and what is legal , so I will know how to proceed .
I am not trying to interpet law .
