Yes, a fun discussion indeed!
I don’t doubt any of our abilities to understand and express the concepts that allow our boats to float and how to change the situation when they are not floating right. Contrary to my earlier mention of semantics, it’s most likely
that we are expressing the same thing in different ways. I am not discounting anyone’s personal observations of the issues, as they are as real as my own observations. Furthermore, I allow that my interpretation of said observations may be incorrect, and that one has to consider both sides of a discussion to reach the truth.
My initial stance on the ‘full’ ballast tank description is based on my observation of where the ballast tank in my boat is in relation to the water level outside the boat. Visual reference of how high the boat sits in the water relative to the sink drain thru-hull relative to the top of the ballast tank under the cabin floor. I reference the top of the ballast tank relative to the hull waterline as a means to help illustrate points that follow. My observation approximates the topmost level of the ballast tank to be at or slightly below the hull waterline, but not above it (on the
From that starting point, I visualize a ‘full’ ballast tank having no effect on causing the hull to sit lower in the water, as equilibrium is met, (contrary to opposing observations). Further, to attempt to support the opposing observation, I visualize the top of the tank needing to be higher than the hull waterline, to thus allow more ballast to make the boat ride lower in the water, when equilibrium is met. Right or wrong, that’s how I visualize it.
Looking back, my entry to this discussion was about the point of whether or not the (equal density) ballast makes the boat sit lower in the water. My position evolved to counter the statement made about an empty ballast tank offering a positive buoyancy effect on the boat.
I counter again…it is less water in the boat, NOT more air in the boat that makes it float higher (not sink). The air in the cabin & in the ballast tank, vent open or closed, is in a static state, not a positive flotation state. Just as filling the cabin with hundreds of air filled balloons would not allow the hull to sit higher in the water. For an empty ballast tank to provide a positive buoyancy effect, the water would need to be in the boat, above and around said tank.
Looking back at the original idea being explored…emptying the ballast tank to float the boat off a grounding. I submit that a boat with a ballast tank level with the hull waterline…no; a boat with a ballast tank level taller than the hull waterline…yes. Yet the former, not the latter, best describes the MacX. That said, I defer to anyone who has actually done it in practice.
Andrew
