raycarlson wrote:dont waste money buying different batts for house or starting,just get two walmart deep cycles on a perko switch and alternate their usage daily.these little 50 HP motors require little to cranck them over so even the smallest 24 size deep cycle will not be stressed crancking your motor over.if by some chance you do have a battery get weak almost all outboards up too 150hp at least , have a rope pull starter in your little tool kit.take it out and use a coupke of times before you acctually have to just so you know what to expect, my nissan 50 starts with little more effort than my evinrude 6 that only has a rope pull.the walmart everstart batts are now made by johnson controls,who also make interstate,sears diehard,optima and several others and they have a 12 or 18 month no questions asked return warranty on them so if you really wanted you could have a planned shorted cell every year and always have new batteries if you wanted to go to that much trouble.
You may be right about not needing a cranking battery . I wondered just how much strain a 50hp could put on a deep cycle battery . In my boat I plan to have two deep cycle batterys on the Batt 2 position , and a cranking battery on the batt 1 position , but maybe 3 deep cycles would be better.
For the sake of the guy who started this thread ,,,,,
The difference between a cranking battery and a deep cycle battery is that
A cranking battery is designed to put out a large burst of amperage for a short time , 300-400 amps for a few seconds .
A deep cycle or house battery is designed to put out a small amount of amperage over a long period of time . Such as 10amps over a 10 hour period.
To use a deep cycle to crank a large engine regurarly will shorten its life , quite a bit.
BUT our engines aren't that big ,,, hmmmm
PS The other big difference is that a cranking battery recharges quickly, where a deep cycle requires a long period to recharge. Thats the big reason the two should never be ran in the "BOTH" position for long periods of time.
