I suppose the simple fix would be to jack it up till it's straight. (short term fix)
Perhaps weld another stiff metal tube to the side of it for a more permanent one ? ( will it damage it if I heat it up ?)
You can see by the pictures just how bad the tire wear is .. it's the same on both tyres on either side.
I only just bought the boat and thought it was just something in the fenders that was too close scraping the rubber off ... so didn't think much of it.
It's hard to see in the picture but the wheels are both bowed out.
Perhaps the last guy towed it with ballast ?
Is this normal for a steel trailer ?
Would hitting a pot hole bow the axle ? I doubt it myself.
I am thinking of perhaps putting dual axles on.
Does anyone know what the rating of these particular axles are ?
BTW it's a 2007
Phill
