But "pride goeth before the fall" or something like that...just waiting for something bad to happen.
Anyway, I have an issue with the turning blocks mounted on the deck next to the mast for my halyards led aft. The original owner simply screwed small 1/2" screws through the fiberglass deck to secure these blocks. One of the screws has pulled loose.
So I figured I would see if I could get to that location from the inside and install bolts/nuts to secure those blocks. Removed the screws holding in the wood frame (or whatever it is called) that is around the DB slot up above the forward dinette seat. You have to slightly "stretch" the piece to get it around the DB slot. However mine didn't stretch...it broke. But I think I can fit the two pieces together with some glue and screw it back in place. The plastic edge trim is the only thing holding it together right now.
So word of warning for anyone wanting to get up in that space on an
I removed all the pieces of foam. Thought I might have to number them or something as I removed them so that I could remember how they went up in there but it was simply a bunch of pieces of foam, mostly irregularly sized, stuffed up in there every which way. So I will just stuff as much back up there as I can and not worry about it if I have a couple of pieces left over. I can easily see the holes where his screws went through the deck. Stopped at Home Depot on the way back to my hotel and picked up some stainless bolts/nuts/washers. Should be no problem.
Still need to figure out my problem with the engine warning horn from last December (last time I was able to get on the water). Took the motor cover off and can see the oil tank/reservoir has a couple of bolts to mount it. Should be able to remove it and check the wiring of that warning horn. Hopefully during the long trailer trip it "jiggled" itself back into working order...and maybe monkeys will fly out of my @$$.
Sailing on König
P.S. I wonder, while I have that piece off and access to that space, if I can figure out how to run a speaker wire from the port side to the starboard side so I can mount a speaker up there....
