Well, wattage is a relative term of electricity flow. 7w 110AC is a nightlight. 7w@12VDC is almost an amp or the amperage equivalent of a 75 watt 110VAC bulb. So wattage is only comparative if you are using equal voltages.Gypsy wrote:Wattage is wattage whether you raise or lower the voltage . A 30 watt unit would be substantially weaker than a 150 watt unit , no matter the voltage. 30 watts won't provide the same cooling as a 150 watt model.
Yes. the amperage is 10 times higher at least. Amperage is the flow rate. 150WAC to 12VDC is 12.5amps on the DC side.A 150 watt 110 vac is the same same as 150 watt 12vdc except the amperage is higher on the DC side .
If your boat had a hole in it, would you rather a 1" hole or a 10" hole? Bigger hole, more flow rate. Which would flood your boat faster? What's gonna drain your batteries faster, a 1 amp of running lights or 12.5 amps of fridge running?
You can get away with pulling that kind of amperage (10 amps) out of 12v for a while. But eventually you will need to charge it back up and the Bayliner probably has a 65amp alternator.On our Bayliner we have ran 110 vac fans that total up to about 150 watts . We run these thru a 700 watt inverter We run the fans all night and have battery the neaxt day , in fact we have stayed at anchor for two nights and not ran the motor in between , and the fans , and the one house battery do fine.
Give it a try. I suggest before you hardwire stuff in, you try it in the garage. Plug that inverter into a battery and then the fridge into the inverter and run it for 12 hours. Then take a digital voltmeter to your battery and see what the drop is. Also, you need to make sure the fridge will "start" when the battery drops to 11.8 volts and the inverter capacity drops.
Good luck and let us know your results.
Many of us are envious of your journey.
