Dimitri wrote:
Moe wrote:
There is, however, an increase in piston, rod, bearing, and crank load due to the higher piston speed (compared to that at the torque peak rpm), as the piston is accelerated and decelerated. And wear goes up as well.
I don't fully agree with this because when the engine is under a greater load, the RPM (and piston speed) is definitely lower. On my boat, it can be as much as 600 RPM's lower under load.
Yes, rpm at WOT heavily loaded is lower than WOT lightly loaded, but reread what you quote from me. I was referring to speed relative to the speed at the torque peak, which is much lower than either WOT speed.
Dimitri wrote:
Although I do agree that wear goes up...and expect that it is due to higher torque on the crank (caused by higher load on pistons and rods).
Under load, the engine applies torque to the drivetrain. The load is irrelevant. The most torque on the drivetrain is that which the engine is supplying. If it is greater than that required to pull the given load at the current speed, acceleration occurs, and vice versa. If the load goes up, deceleration occurs until the load (drag) decreases to match the torque, and vice versa. Under deceleration with engine braking, the load applies torque to the crank.
Dimitri wrote:
And about slippage, I didn't say there was no slippage (nice figures though). My point was that the slippage would not be enough to significantly reduce the load (unless you are running the outboard in a barrel or something)
What I wanted you to see is that it is possible (with the right prop), to narrow the rpm range between loaded and unloaded.
Dimitri wrote:
You may call it "overpropped" ... but in a practical sense, when I have full ballast and 7 people aboard and can only turn 5300 RPM, I'm not putting out max HP because I need to be between 5500-6000 for that.
I hate to break the quote here, but need to say that none of us, except the guys who run the motors on the dyno, know what the horsepower curve looks like in the last 1,000 rpm. Mercury's service manual says the EFI version gets peak HP at 5750, which is conveniently halfway between 5,500 and 6,000 rpm. For all we know, the horsepower may be within +/- one to two HP from 5,000 to 6,000 rpm, not just 5,500 to 6,000 rpm. My point is, you MAY have as much horsepower at 5,300 rpm as you do at 5,900 rpm.
Dimitri wrote:
Next day, I go out by myself with no ballast and I can get up to 5900. I'm not about to switch props in the middle of those two days....as much as my uncle was going to switch props between 80# and 200# skiers. The lower RPM at load argument pretty much disproves the argument that you are putting out 50HP at load and 35HP when not at load, don't you think?
Whoa! I never said that. In fact the opposite. My point was that in the last 1,000 rpm with two-valve engines of this size, the HP at the loaded and unloaded rpms is the same or very close. It was on that I based the high/low miles per hour. The 35HP had nothing to do with this.
Dimitri wrote:
Now, if you change that to higher torque at load (with lower RPM), I could buy that.
That's correct. At rpms above the torque peak, torque is decreasing as speed increases. If the torque is decreasing slower than rpm is rising, horsepower increases as speed goes up. If torque is falling the same speed as rpm is rising, horsepower remains level as speed increases. If torque is falling faster than rpm is rising, horsepower is falling.
Dimitri wrote:
Both yours and Chip's arguments indicate that the power is only proportional to the speed (RPM) but I am stating that power is proportional to both engine speed AND load. Load will increase as weight (and/or pitch) increases.
Then you are wrong. Power is proportional to both engine speed and TORQUE, which is supplied by the engine, not the LOAD. Increasing the load does not increase the engine's power output.
Dimitri wrote:
The main point here is that if my uncle hadn't tried to pull the fat slalom girl out that day, that motor could have lasted another 10 years. Can you agree with that??? Yes, I know you can make the point that maybe the motor would have broke on the next ski despite who was being pulled out...but that does this sound as likely?
Actually your extremes there sound equally unlikely. The motor might not've broken on the next pull, but it wasn't long for this world, certainly not another 10 years.
Dimitri wrote:
Afterall, we don't typically do high tech imaging on our crankshafts before and after an incident like this...so of course, it is hard to prove beyond all doubt. But if you (or other readers) do agree with me, then it proves the point that there is significant additional stress and wear on the motor when it is under high load.
Sorry... but it's an ancedotal childhood memory that doesn't prove anything.
Dimitri wrote:
I believe that both of these last two paragraphs prove that a fully ballasted boat being pushed around at WOT is more stressful to the "machine" than a light boat going at WOT...so, there is where I stand on this topic.
There's no doubt in my mind
Dimitri wrote:
I will agree with you that if you go with a lower pitch meant for full ballast, the wear will be less...but the force required to push the boat is still proportional to the weight so the difference is not zero.
If we say your horsepower at WOT 5,300 rpm is equal to the horsepower at WOT 5,900 rpm, the force required to push your boat to its top speed when heavily loaded is EXACTLY equal to that required to push it to its top speed when lightly loaded.
This is where it really gets good now. PAY ATTENTION! If we say your horsepower at WOT 5,300 rpm is LESS THAN the horsepower at WOT 5,900 rpm, then the force required to push your boat to its top speed when heavily loaded is LESS THAN that required to push it to its top speed when lightly loaded.
While you have a firm grasp that load increases with weight, you ignore the fact that load also increases with the speed that's obtainable with a lighter weight. That keeps you from understanding that the load is the same (or less) when WOT with a heavily loaded boat, as it is when WOT with the lightly loaded boat.
Dimitri wrote:
Talk to commercial barge folks who use outboards...they don't go fast, but they burn thru smaller motors pretty quick.
And in their short life, they've done as much or more work as "smaller motors" on lighter boats.
Moe
