Heres Pictures of What we are putting in!
jpatter wrote: We just to intend to use 18 gauge speaker wire since they can't pull that much amperage.
jpatter wrote:Well We'll take the plunge on the marine wire for safety's sake. But as far as the outlets and stereo what gauge wire are yal running to yours?Also any clue on what kinda fuse should be between the battery and fuse panel. Each breaker on the panel has a 30amp fuse but it says it needs one between?
30 Amps!!! Really?!!!Just because you have 30 amp breakers
