Okkkkkkkk … I understand now !seahouse wrote:Hi Versatile-
Sorry to hear about (and see!) your problem.
A couple of questions...
Is it possible that the boat was trailered with the ballast full and the yield strength of the axel exceeded (bending it)- giving the negative wheel camber? When the weight is removed (draining the ballast) the axel would not straighten again?
I think the weight of a full ballast would exceed the capacity of the trailer by a considerable margin. If the springs then bottom out the rated load capacity of the axel becomes significantly reduced, compounding the situation.
When you purchased the boat did you notice the camber problem and make mention of it at the time?
- Brian.
I tough that I had to keep the ballast when trailering and motoring and emptied it when I was sailing …
Thank you very much, from now on I will do things properly.
Sorry, I should have read the manual before … and know how to do a crash stop to bring the boat in position in the trailer !
Do you think I should empty the ballast before the winter arrives … because it will get down to 0°F out here ?
