I'll warn everyone now, this one may be a little dry for some peoples taste....
Moe,
I am having trouble finding references to US Racons for US offshore waters being S Band only, so maybe I am misreading my coast guard publications here.... but could you clarify the S-band reference..I thought they were all X, and some had S in addition.
Seems all my new marine equipment is X band, my
Furono 1623 operates on 9410 MHZ +/- 30 mhz
From the USCG tech page...
radar beacons
Racon Technical Characteristics
All racons used by the USCG are frequency agile type, designed to measure the frequency of every incoming radar pulse, and transmit an approximately 25 microsecond Morse-encoded response less than 700 nanoseconds later back to the radar on that frequency. The Morse-encoded response is encoded such that the length of one dash is equal to that of three dots, and the length of one dot equals that of one space. All racons operate over the frequency range 9300-9500 MHz marine radar band (X-band), and most additionally operate in the 2900-3100 MHz marine radar band (S-band). Racon range is approximately line-of-sight range, normally over 15 nautical miles, although actual range depends upon a number of factors, including mounting height, atmospheric conditions, and racon receiver sensitivity setting.
S-band racon antennas should be suitable for responding to radars using horizontal or vertical polarization. X-band racons should respond to radars using horizontal polarization. X-band antenna vertical divergence ranges from about 8 degrees for fixed installations, to 18 degrees for installation on buoys. S-band antenna vertical divergence is 22 degrees. Radiated power is 600 milliwatts. Receiver sensitivity is about -35 dbm.
Or am I misreading you for discussing older and higher power mobile shipboard radars, I.E the sperry, raytheon, furuno naval and weather radars ie..marine radars X-band 2-4 cm 8-16 GHz long-range precipitation radars C-band 4-7 cm 4-8 GHz long-range precipitation radars S-band 7-15 cm 2 to 4 Ghz
I think the SOLAS requirements for Shipping now are both X band and S band have to be on board the big guys..... I know at 300 tons....
2.3 All ships of 300 gross tonnage and upwards and passenger ships irrespective of size shall, in addition to meeting the requirements of paragraph 2.2, be fitted with:
2.3.1 an echo sounding device, or other electronic means, to measure and display the available depth of water;
2.3.2 a 9 GHz radar (xband), or other means to determine and display the range and bearing of radar transponders and of other surface craft, obstructions, buoys, shorelines and navigational marks to assist in navigation and in collision avoidance;
The S-Band requirement to carry is in addition.
and reads as follows
2.7 All ships of 3000 gross tonnage and upwards shall, in addition to meeting the requirements of paragraph 2.5, have:
2.7.1 a 3 GHz radar or where considered appropriate by the Administration a second 9 GHz radar, or other means to determine and display the range and bearing of other surface craft, obstructions, buoys, shorelines and navigational marks to assist in navigation and in collision avoidance, which are functionally independent of those referred to in paragraph 2.3.2; and
So if one could get a good omni feed antenna pointed at the X band detector that should cover all shipping traffic and fixed beacons. Realizing of course that the beacons will only respond when someone elses signal hits them... Thos beacons also have lights and horns tho for when we stray to close.
Thanks
|>[/url]
