I would appreciate some feedback about which motor to get. I am looking at 2 of similar age, one with an e-tec 50 and one with a tohatsu 90 tldi. The boat with the tohatsu is 1 year newer, but has fewer upgrades and is $3000 more. Will I be okay with the 50 or will I be kicking myself that I didn't get the bigger motor? Since I've never owned a boat, I have nothing to compare performance against. I plan to do some extended trips with my girlfriend (4-7 days into Desolation Sound), so it will be fairly loaded when we go... $3000 would buy a lot of equipment, including a tender with motor, so it's a tough call. I just don't want to find out that the 50 struggles with the weight and the currents without saving much in fuel economy and I end up disappointed a year from now. Reliability and low maintenance for the e-tec does seem to be very good though (at least from the evinrude site -- service only every 3 years??), so there's some savings there as well.
What kind of a difference in fuel economy would there be between the two engines if they were identically loaded and cruising at the same speed, say 10 mph? The Tohatsu is 1267 (77.3 cu.in.), which is about 1.5X the displacement of the e-tec. Does that equate to roughly 1.5X fuel consumption? I know it won't be quite that bad, since the Tohatsu doesn't have to work as hard for a given speed... What will the difference in top end be between the two? Which one would you get if you were buying today??
Thanks!
